Question [Merged topic] Miscellaneous questions about K 1.6
16 years 1 month ago #67246 by sozzled
G'day, Howard. Although your question is a little off-topic, I'll do my best to answer it as comprehensibly as I can.
freedomcoach wrote:
I'd like to know if there has been any further release on Kunena 1.6 .0
One of the great features about this website is the tireless work undertaken by the project team to keep people informed about the latest developments. There are, of course, news updates on Twitter, updates on Facebook, updates in the JED and in Joomla! People. But the home page of Kunena.com is always updated when there is a new version of Kunena.
But that's not all! :woohoo: Just below the Kunena Control Panel in your Administrator site, if you are using K 1.6.x you will be advised of the availability of new updates.
Currently, K 1.6.0 is the most recently-released stable version of K 1.6.
The topic has been locked.
16 years 1 month ago - 16 years 1 month ago #67248 by sozzled
techgopost: I replied to your general question about font size.
sozzled wrote:
Font size: the font size that you have on your website is taken from the font size used by your site template CSS.
I don't know anything about your website and so I really can't help you any further until we know more. If you use Firebug for Firefox then you will be able to find exactly what part of your site template CSS is controlling the font size on your whole website and, by changing that, you will change the font size in Kunena on your site, too!
Questions about font-size, colour, style etc. are not normally answered in the Common Questions category. They are answered in the Template and Design category. Here are some search results that you will find useful. If you still cannot find an answer and you don't have a couple of minutes to use Firebug then please provide us with the URL of your site and someone might be able to suggest a better solution to your specific problem .... otherwise we can only continue to give general information.
Last edit: 16 years 1 month ago by sozzled.
16 years 2 weeks ago - 16 years 2 weeks ago #70458 by Laacis
Replied by Laacis on topic A couple of questions
Hi all.
Setting up kunena 1.6.1, i have noticed couple of things that i need to add/change
(I have added pics,to better understand me)
1. How to add in profile a new string,like Personal Text ,but in my case,i need that,only administrator can add that string to some user.
2. This "post count" in my forum is in big font, how to set it smaller?
3. How to resize images that has been added to my forum? (in kunena 1.5 , in backend i was able to set this,but how about kunena 1.6 ? )
( www.bildites.lv/images/9bvt7dl7fwprvzruma6.jpg )
4. With Firefox 4.0 Beta 7 , images aren't opening well, but in IE , it's all OK, is there a fix for this?
www.bildites.lv/images/55gytebtr64d6crn9p0q.jpg
5. How to add or remove images from "post reply", and why in backend: Emoticon Manager , there are a lot of images,but in Boardcode,there are just couple of them?
6. uhh,don't know how to explain this,but look in pic- i think you will understand,what i mean :)
www.bildites.lv/images/60mvsq2e72kyvuh11g8d.jpg
7. How to make kunena latest post module look like this?
www.bildites.lv/images/6z37xiver7szt9tu1s6.jpg
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 1024M | Max file upload: 1024M
Joomla default template details : t3_joomla | author: | version: 2.0 | creationdate: 2010-11-09
Third-party components: AlphaUserPoints: Disabled or not installed | CommunityBuilder: Disabled or not installed | Jomsocial: Installed (Version : 1.8.11) | UddeIm: Disabled or not installed
Last edit: 16 years 2 weeks ago by Laacis.
16 years 2 weeks ago #70491 by xillibit
Replied by xillibit on topic A couple of questions
1°) You can edit the kunena user profiles in backend
2°) Look with firebug (firefox extension) if can modify something
3°) You can set in backend the maximum width and height for the images uploaded
4°) This will be fixed in k1.6.2, i have just tested on Fx 4.0 beta 7 and it's works well under k1.6.2
5°) What do you mean by add or remove images from "post reply". There are exactly the same numbers of emoticons in boarcode and in backend
6°) I don't understand your five on the image ? For the 6, i do'nt know why the tooltip isn't a bit larger, i think your Joomla! template changes the things in kunena
7°) If you know the CSS you can change the module style
16 years 2 weeks ago #70500 by Laacis
Thank you for your reply.
1. - I didn't find where, can you,please, tell me?
3. - If it is: Thumbnail Width or Maximum Image Width (in Forum Configuration : uploads ) ,then it isn't working for me!
5 - couple of smileys arent in Boardcode, but they are in Kunena Emoticon Manager.
7 - My CSS knowledges are too small to do that :(
16 years 2 weeks ago - 16 years 2 weeks ago #70519 by sozzled
Replied by sozzled on topic Re: A couple of questions
K 1.6 has not been tested with Firefox beta. We don't always test beta versions of web browsers (because they're subject to change). It's nice to know where web browser developers are heading (in a strategic sense) but that doesn't mean that the Kunena project is going to make any accommodation for those things now. Thank you for the information.
If you CSS knowledge is limited then you should not be using beta versions of any software.
Do you understand the term "backend"? The Kunena User Manager facility is what he was referring to.
Last edit: 16 years 2 weeks ago by sozzled.
Time to create page: 0.153 seconds
