- Thank you received: 11
Question [Merged topic] Miscellaneous questions about K 1.6
Also, does anyone know if the forum profile menu plugin for Jomsocial has been updated yet to work with Kunena 1.6?
Thanks.
mindriot wrote: Im wondering, having never done it on any kunena installation before, how in 1.6 RC1 I need to make settings changes to enable public posting in only one particular forum category with captcha protection, and if its even possible.
Still not possible, will be possible when Joomla 1.6 become stable.
mindriot wrote: Also, does anyone know if the forum profile menu plugin for Jomsocial has been updated yet to work with Kunena 1.6?
Thanks.
Yes, this plugin is updated and works well with Kunena 1.6 (as you can see here at kunena.com
Regards
Silly question but where do I find the Jomsocial menu plugin
When any liks are clicked I get a page devoid of any template styling, just a white page with the unstyled menus etc.
on this site the path used is :
/forum/myprofile/showset
whereas my site seems to be trying to use :
component/kunena/myprofile/showset.html
this difference seems to exist for all the links in the menu plugin.
Could it be the forum is set as the default frontpage of the site in the Joomla main menu?
Any ideas?
We are just about decide how to do with this.
In the meantime you can use Joomla menu to create links to kunena pages.
Regards
