Important After upgraded forum shows broken links won't work
  • skinny
  • skinny's Avatar Topic Author
  • Offline
  • New Member
  • New Member
  • Kunena lover. I need professional help!
16 years 2 months ago #52536 by skinny
Tried everything. Nothing is working...
Contact info: skinny-blog.com/contact-me
(951)-262-3550 EXT 2
Blackberry PIN: 4036ce1f
  • skinny
  • Offline
  • New Member
  • New Member
16 years 2 months ago #52538 by skinny
Also i looked through cpanel (PHPMYADMIN) I cannot find jos_kunena anything either.
16 years 2 months ago - 16 years 2 months ago #52540 by sozzled
skinny: The jos_kunena_* tables - mentioned in Matias' post earlier - were added during, or after, the constuction K 1.6 ALPHA ... possibly in K 1.6 ALPHA2 or later (I can't remember when, exactly). If you would like me to look at your specific problem, please send me a PM. I strongly suggest that you make a backup of your website now, in case my help causes more problems and you need to revert back to what you had before.
I will need administrator access to your website. Do you have Skype? It helps if we can talk through the issues in real time.
16 years 2 months ago #52545 by xillibit
skinny wrote: Tried everything. Nothing is working...
Can-you please explain what didn't worked ?
The next time please don't install an alpha version on a production site without significatives tests.
16 years 2 months ago #52610 by Matias
I would like you to describe what you have tried and what happens when you try it. It's very hard to imagine what is going on without getting details what you have tried and what were the results from that.
Did you try to remove Kunena Menu? Or did you try to install K1.6 back, uninstall it and install K1.5?
Let Sozzled to help you -- he will keep me updated what is happening and ask for my help if needed.
Time to create page: 0.270 seconds
