Solved Avatars?
14 years 5 months ago #125071 by doribeeler
Avatars? was created by doribeeler
This may sound redundant or completely naive... I am running 1.7.2 with Joomla 2.5.4 and do not see how to add an avatar image to a Kunena profile. I have logged into the forum and selected the 'Profile' menu item and I am unable to load an image for the avatar. Am I missing a plug in for Kunena or another component that has to work with it for this to function...? Appreciate an answer for the Noobie question...
Config report:
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 64M
Joomla default template details : rt_somaxiom | author: RocketTheme, LLC | version: 1.6.3 | creationdate: February 19, 2012
14 years 5 months ago #125073 by sozzled
Replied by sozzled on topic Avatars?
Hmmm ... puzzling. Just from curiosity, is your site being hosted by GoDaddy?
14 years 5 months ago #125075 by doribeeler
Replied by doribeeler on topic Avatars?
no, hostgator... they are usually pretty hassle free...
14 years 5 months ago #125077 by sozzled
Check your folder/file permissions. See Securing Kunena (set all folders and files according to the recommended values for Joomla) and make sure that you are the owner of the folders and files. Then try again.
14 years 5 months ago #125085 by snilloconator
Replied by snilloconator on topic Avatars?
I see you're using rt_somaxiom as your joomla template. By any chance do you have build title spans turned off for your forum profile?
14 years 5 months ago #125137 by doribeeler
No, I havent turned them off... is that what you are recommending?
Time to create page: 0.153 seconds
