Solved [Resolved] Posts on forum disappear!
15 years 2 months ago - 15 years 1 month ago #108061 by astrogoal
I was with joomla 1.23 and kunena 1.6.4 when I realized that some messages disappear..
Imagine a forum when some messages .. go away.
I founded that messages only apparentely disappeared.. If I try to "quote" I can see the original message, but NOT on the forum.. It is terrible :(
I try to upload to kunena 1.7, but nothing has changed... i'm really deasperate.. i'm not really sure if is a template problem..
Anyway i changed template, but nothing...
Last edit: 15 years 1 month ago by astrogoal.
15 years 2 months ago - 15 years 2 months ago #108087 by xillibit
When you edit the blank message what do you see ?
Last edit: 15 years 2 months ago by xillibit.
The following user(s) said Thank You: astrogoal
15 years 2 months ago #108091 by astrogoal
When I edit an invisible message I see that message exists... I tried to edit some message, and also to add some letters to the message.. but all disappear on the standard forum layout. You can see the original message only if you quote or edit.
15 years 2 months ago #108094 by astrogoal
Also with firebug TEXT of message does not exist..
This is the code of the invisible message..
<td class="kmessage-left"> <div class="kmsgbody"> </div>
And this is the code for a visible message...
<td class="kmessage-left"> <div class="kmsgbody"> <div class="kmsgtext"> Visible message </div> </div>
:silly:
15 years 2 months ago #108118 by xillibit
Can-you make a sceenshot when you edit a blank message to see what there in this message ?
15 years 2 months ago #108136 by astrogoal
Yes sure... In the message ther is the text ...
