Question Category Icons Keep Disappearing
15 years 1 month ago #108311 by RCheesley
No idea what that means Andy, but setting the permissions then doing a search/replace for the quote marks resolved it for me!
Ruth
15 years 1 month ago #108312 by AndyInSpain
Oh, sorry Ruth, this was what I mentioned a few posts back.
www.refresh-sf.com/yui/ is the online service for minifying CSS files. I have (or had) a strong suspicion that the CSS is becoming corrupted by using it to minify the CSS after editing. If you haven't used it to minify your CSS files then the problem is obviously not happening there!
Cheers
Andy
15 years 1 month ago #108566 by Matias
Yes, something is really corrupting css files. Are the original files corrupted?
Ass css files are static, there are only few possibilities of what can be happening.
1) Joomla plugin corrupts the files
2) Apache plugin does something for those files
3) Caching does it
4) Something else does it
I know that it isn't Kunena..
15 years 1 month ago - 15 years 1 month ago #108582 by AndyInSpain
Hi Matias, hope you are well.
Well,I was almost convinced that the CSS was becoming corrupted during the minifying process. I say this because I reset our forums' configuration, which restored the icons, and all was fine for two weeks. Then I made some changes to the CSS, minified it and the next day the icons disappeared again. I don't pretend to understand why, nor why there is a delay. And in any event, Ruth had not made any changes to the CSS but still had the problem, so now I am not so eager to blame the minifying process.
Now I have reset the forums configuration again, but the icons have not reappeared this time. My next step will be to uninstall and reinstall Kunena. This is a real pain but it's the only solution I have. And as we don't know for sure what is corrupting the CSS, there is no guarantee it won't happen again.
Last edit: 15 years 1 month ago by AndyInSpain.
15 years 1 month ago #108657 by KiberLovag
Just give it a try, close every css, rename the folder containing the original css (just for backup), and upload the factory-default css just see, if you can see icons or not... if yes, than search for " in the saved ones... maybee the same problem, but the interesting thing that you can get to this error by several ways... :whistle:
KiberLovag
Ócsa, Hungary
15 years 1 month ago #109120 by Matias
It's a good idea to make a copy of the template. Kunena 1.7 doesn't itself touch the files and I really don't see any reason why anything else would like to do that, too.
BTW Kunena 2.0 will have its own CSS minifier and compiler that creates new files from the original ones (after every update on either CSS or template settings).
Time to create page: 0.145 seconds
