Question Category Icons Keep Disappearing
15 years 3 months ago - 15 years 3 months ago #105040 by AndyInSpain
Hi all,
A weird one this. Our installation of K1.6.5 was chugging away quite happily, using the default (Blue Eagle) template when, for no apparent reason, the category icons disappeared from the front end, even though they were still on the server (i.e. they hadn't been deleted in error).
I failed to find a reason for this. I reinstalled K1.6.5 but no difference - the icons were still missing. So I switched to using the Example template, just to see what would happen. The icons were there. So I decided to use the Example template until I could solve the problem with Blue Eagle.
But then, a few days later, the category icons disappeared from the Example template too. For no apparent reason.
I then tried another template called Euro Blue - and a few days later the same thing happened. Then I tried two more templates and the same thing happened - after a few days (the number of which varies) the category icons disappear.
If I switch from the current template (where the icons are visible) back to one I had problems with, the icons are not visible. In other words, once the category icons are dead in a particular template, they stay dead.
This is such a bizarre problem that I just don't know where to start looking. The path to the category icons remains unchanged ("category_images/").
Does anybody have any idea about solving this one?
Many thanks
Andy
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 10M
Joomla default template details : jsn_epic_pro | author: JoomlaShine.com | version: 4.2.0 | creationdate: 06/22/2011
Kunena default template details : KProSilver | author: ExtensionTemplates.com | version: 1.6.2 | creationdate: 2011-01-01
Third-party components: UddeIm
Modules: Kunena Latest 1.6.4
Last edit: 15 years 3 months ago by AndyInSpain.
15 years 3 months ago #105054 by sozzled
"Example" template: please read my comments >>> here <<<
Setting up category icons: see Category icons
"No apparent reason": I do not believe in ghosts; everything has a reason. We're here to answer questions about the software that is designed, developed and maintained by the Kunena project. Your configuration report shows that you are using a third-party template. If you have a problem with running Kunena with a third-party template then you should address your issues to the author(s) of that template.
As the release notes for all recent releases of Kunena have consistent stated, "Some users of third-party templates written for older versions of Kunena will find that their templates may not work with this latest release because changes were necessary in order to fit with the new J! 1.6/1.7 CMS." This will probably be more starkly realised when K 1.7 is released soon.
I'm sorry, I don't have any other suggestions at this time, except to advise that you use the Blue Eagle template and follow the advice given in Category icons .
15 years 3 months ago #105057 by AndyInSpain
But as I said in my post, Sozzled, I was using the Blue Eagle template when the problem started. I want to keep using the Blue Eagle template because it's perfect for our use and our site members love it. But as it stands, its category icons don't work. I shall read your comments about category icons.
I said "apparent reason" because that's what it is: a problem which, on the face of it, has no discernible cause, for example changes in site configuration or the addition of extra components. Of course the problem has a cause. And I have only used 3rd party templates in an effort to keep the forums online rather than take them offline while the problem is solved.
Many thanks for your help
Andy
15 years 3 months ago #105060 by sozzled
AndyInSpain wrote: The path to the category icons remains unchanged ("category_images/")
Your images need to be located in <root>/media/kunena/category_images/
Now, when I go to your website (as I did about 2 minutes ago) I see category icons. So, can you please show us what the situation looks like with the Blue Eagle template. I am trying to understand what you mean by these images "disappearing". I mean, do you see nothing, at all?
15 years 3 months ago #105064 by AndyInSpain
The current template is now Blue Eagle. Thanks Sozzled!
15 years 3 months ago #105068 by sozzled
Your site shows the following information:
#Kunena span.kreadforum, #Kunena span.knotloginforum { background: url("&amp;amp;quot;../images/icons/folder_nonew.png&amp;amp;quot;") no-repeat scroll left center transparent; height: 32px; width: 32px; }
This website ( www.kunena.org ) defines this thing as follows:
#Kunena span.kreadforum, #Kunena span.knotloginforum { background: url("../images/icons/folder_nonew.png") no-repeat scroll left center transparent; height: 32px; width: 32px; }
Therefore, somewhere, you've got these extra characters being inserted into the "background: url( ...)" rule. I don't know how that can happen.
My advice is to put your Kunena configuration settings back to their default values. Do you know how to do that?
The following user(s) said Thank You: AndyInSpain
Time to create page: 0.154 seconds
