- Thank you received: 566
Question 1.6.0-ALPHA | 2010-05-30 | 2587 - Community Builder login integration is not working
16 years 1 month ago #57005
by Matias
Replied by Matias on topic Re: Kunena 1.6.0-RC2 # 3181 - Community Builder login integration is not working
Please use internal test category on test builds (which are not public).
Issue has been fixed and will be available in the next build.
16 years 1 month ago #57064
by kross76
Replied by kross76 on topic Re: Kunena 1.6.0-RC2 # 3181 - Community Builder login integration is not working
Kunena 1.6.0-RC2 | 2010-08-18 | 3237
Tried it in this build. Kunena is now detecting Community Builder, but the login fields still to not work if you've selected the CB - email address only as the login ID>
16 years 1 month ago #57138
by Matias
It's odd if you integrated login to CB..
This is because of it should send the login information to CB instead of Joomla.
URL?
URL?
16 years 1 month ago - 16 years 1 month ago #57142
by kross76
Last edit: 16 years 1 month ago by Matias.
16 years 1 month ago #57144
by Matias
I need to talk with CB team about this. I just verified that it does use CB to login.
16 years 1 month ago #57647
by kross76
Installed build 3252. This features now works "functionally". You can enter the email address in the "user name" field, and you will be logged in. There is still a minor issue. The login field still says "user name" rather than "email address". The CB functionality in their login module calls out the right name (user name or email address) depending upon the option selected in CB configuration.
Time to create page: 0.223 seconds
