Question Kunena menu active Tab problem
15 years 8 months ago #87124 by profesionalas
SOLVED IT.
In ../public_html/administrator/language/en-GB
file: en-GB.com_kunena.install.ini
Changed menu names to my language and then created menu. Now everything ok.
So there is a bug if in kunena menu You can't change names, because after it in forum menu not showing active menu tab.
15 years 8 months ago #87133 by sozzled
Replied by sozzled on topic Re: Kunena menu problem
profesionalas wrote: So there is a bug if in kunena menu You can't change names, because after it in forum menu not showing active menu tab.
No, there is not a bug in Kunena. It's a Joomla issue. Jooomla 1.5 is finicky with menu items.
There are a few methods that will fix these issues. You found one method. There is another method, too, written in the Wiki article Customised Menus .
Thank you for writing about how you solved the problem. I am sure that your idea will help others, too.
