Sticky User registration and/or general login issues
13 years 5 days ago #150938 by havocwreaker
Sozzled, thank you for pointing me to this thread. I didn't catch it in a search.
I fixed the problem by enabling the Joomla login in the Joomla integration plugin (was disabled) and turned off the Jomsocial login in the Jomsocial integration login.
Thanks again!
12 years 4 months ago - 12 years 4 months ago #157466 by azidahaka
Hi all, i was wondering if there is a way to avoid manually activating all users, for it requires one to keep a costant eye on the forum subscriptions to avoid people re-registering or complaining due to having to wait to participate in discussions... to give a good service one should have to be online at all times, something out of my hands :/
[strike]also the forum uses as default starting tab the "recent topics" one.. is there a way to tell it to just start in the normal forum sections list?[/strike] found it myself, sorry.
previous problem still remains!
Last edit: 12 years 4 months ago by azidahaka.
12 years 4 months ago #157471 by xillibit
Is-it intented that you want register each user one by one ?
12 years 4 months ago - 12 years 4 months ago #157472 by nutter308
This is a joomla setting is it not?
I thought the default behavior is users are able to register and require email activation before they can login.
To achieve this behavior in your admin backend go to users->options
Set Allow User Registration to yes
Set New User Account Activation to self (I am assuming yours is currently set to admin)
You should no-longer have to manually activate new user accounts.
hope this helps!
Last edit: 12 years 4 months ago by nutter308.
12 years 2 months ago #159047 by darthcricket
It has been a while since I needed to register a new user, I had no problem initially when I installed Kunena. It won't work for me this time.
Thanks :dry:
htaccess: Exists | PHP environment: Max execution time: 45 seconds | Max execution memory: 128M | Max file upload: 24M
Joomla default template details : siteground-j16-20 | author: SiteGround | version: 1.0.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.6 | creationdate: 2014-07-28
Plugins: None
Time to create page: 0.147 seconds
