Sticky User registration and/or general login issues
13 years 5 months ago #138106 by sozzled
Please provide your configuration report so that we may be able to diagnose what may be happening in your case.
13 years 5 months ago #138125 by lenhuhiep
Thanks forum help me compoleace website: online360.vn
and there some way of integrating my login in the forums with joomla?
13 years 4 months ago #138469 by deniniko
Replied by deniniko on topic User Registration
Problem when trying to register a new user...it says .mail problems (so it just cant send an email as i understood)! thanks
13 years 4 months ago - 13 years 4 months ago #139449 by powsurfer
Hi
I have recently installed a new copy of the most recent download of Kunena. The issues I am having at present are as follows: -
A new user cannot register - with the standard login (no captcha) after adding their info it takes them back to the same screen with no info other than saying to complete all fields... *required fields... with the password field now empty.
The only users so far are the admins using their existing main site login details.
I have since added a captcha in the hope that a change may resolve the issue but it has made no difference. The captcha doesn't even appear on teh registration page.
The other main issue so far are the page links for top and bottom of the page. The both revert to the main site.
The main site is htfcfans.co.uk
The forum is at htfcfans.co.uk/forum/
This is the go to bottom link htfcfans.co.uk/#forumbottom
Hopefully can get a quick answer to this so I don't need to uninstall and start again with a different forum. The log file is attached.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 10M
Joomla default template details : samsara365 | author: Snowrat | version: 3.0 | creationdate: 30/11/12
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 2.0.3 | creationdate: 2012-11-24
Kunena version detailed: Kunena 2.0.3 | 2012-11-24 [ Reconciliation ]
Third-party SEF components: AceSEF 2.5.4
Plugins: None
Last edit: 13 years 4 months ago by powsurfer. Reason: Removed visible email address - I attached the txt file but it is being shown to all
13 years 4 months ago - 13 years 4 months ago #139451 by sozzled
*** Topics merged ***
G'day, powsurfer, and welcome to Kunena.
If you read the FAQs page, or msg #2 of this topic, you will see that Kunena is not responsible for user registration. I do not know what registration procedure you are using, or what login procedure you are using, but Kunena should use whatever you would normally use and however those registration and login procedures are configured. If they are configured wrongly then Kunena will use those things wrongly.
Last edit: 13 years 4 months ago by sozzled.
13 years 4 months ago #139452 by powsurfer
Hi and thanks for your quick reply.
The following section you referred me to does not have the correct links/paths to follow. None of these exist in my up-to-date versions of Joomla and Kunena.
You can change whether you allow users to register. This is done (in Joomla) with the setting
Global Configuration » System » User Settings » Allow User Registration = Yes / No
You can provide your users with a place to login (in Kunena) with the forum setting:
Forum Configuration » Integration » Integration Options » Login and Registration
I am not using any other login procedure other than the standard 'create an account' link within Kunena at htfcfans.co.uk/user/registration
The only users who can login at the moment are those logged into the main site.
Q -I have done some reading around - is it that I need to create a registration/login from within Joomla, not Kunena and set the correct permissions?
Q - Do you have an answer (or can point me to the solution for the other problem I mentioned?
Q - is my'confidential' log file viewable by all?
Many Thanks
Time to create page: 0.287 seconds
