Merged Invalid Token
I just had this exact problem - in fact I've had it before. I appreciate this is an old topic, but posting here in-case others find the same. Also this is a Joomla! issue, not Kunena - I'm sure of that.
Invalid tokens have been caused for me because of having the system-cache plugin enabled. This caches whole pages including the login modules, both in Kunena and other pages on the site. effectively it can end up looking like you are logged out - because you are seeing a cached page.
My setup has cache enabled in the site-global configuration, but the system cache plugin, must be disabled or I get all sorts of problems.
What I can't work out is how that system cache keeps getting turned on!
Hope this helps someone one day.
Rob
- farmerinmo
What "SEF" where you using? Were you, for example, using sh404SEF?
