Important [Resolved - user abandoned Kunena] General advice about Joomla, Kunena and website design
15 years 4 months ago #82921 by kici
Replied by kici on topic Re: Help resizing the forum
nah thanks for all the help, but a forum isn't supposed to be half a page withing a website, it isn't any web template that's causing it i tried the original ones also.
as i stated its fine no worries, just for future users it will be helpfull if they dont have to go thru the same, a forum is supposed to be a forum, not a forum inside a website, already found how to link users with phpbb so anyways good luck
15 years 4 months ago #82935 by yuzef
Replied by yuzef on topic Re: Help resizing the forum
maybe to solve it this :
I saw your modules are applied to the forum page too, that easy.. do not include your module in forum page. (that must be in module position --> there menu to access it, dont chose link to forum menu.
Love Simplicty
read...... and learn........
My Joomla Test Site
15 years 4 months ago #82938 by fxstein
Replied by fxstein on topic Re: Help resizing the forum
kici wrote: nah thanks for all the help, but a forum isn't supposed to be half a page withing a website, it isn't any web template that's causing it i tried the original ones also.
If you would read the very basics of Joomla you would have found out that you can make Kunena your homepage and remove all other modules and menus showing. However you need to invest into learning how to do the very basic configuration of Joomla. These changes take less than 5 mins. If that is too much to ask, you might be better off not using Joomla and Kunena.
Hope this helps!
Time to create page: 0.266 seconds
