Question Joomla/Kunena menu issues?
15 years 10 months ago - 15 years 10 months ago #82739 by Phoenix
I sure appreciate the approach you took with this tutorial ... especially the "branches" that can be followed if something in it is unfamiliar. I wish more people would take this approach as it helps a great deal for people like myself with the capacity to learn but no real way to judge "conflicting advice" for themselves without a larger frame of reference. Your article makes gaining that frame of reference much easier because it focuses on "probabilities" rather than "absolutes" and gives good sources for doing further research into conflicting opinions.
Thank you for writing it and I will certainly explore it and the links it leads to further as I move upwards in my own "learning curve".
I have a thread in in the Joomla forum where I posted about my issue after I realized it was not about Kunena which also talks about some of the challenges faces by people in my situation.
forum.joomla.org/viewtopic.php?f=544&t=587463
Thank you again for all the help you (and many others) provide in this and other related forums.
Phoenix
Last edit: 15 years 10 months ago by Phoenix.
15 years 10 months ago - 15 years 10 months ago #82741 by sozzled
Thank you for the reference to your discussion topic at forum.joomla.org and thank you, also, for your kind remarks about the help that we try to give to the community. I appreciate and I do try to understand how overwhelming to new users some of these issues must appear when they are are commonplace to those of us who have been doing this stuff for a while. Sometimes, though, our understanding is not always that good and we occasionally need to be reminded if we've missed something important.
Last edit: 15 years 10 months ago by sozzled.
15 years 10 months ago - 15 years 10 months ago #82747 by Phoenix
Another example just happened to me along the same lines (and since this has been moved to off topic I may as well add it).
I was just writing my first article for my new website and because it was partly a copy and paste from an email I had sent ... the formatting was all wrong. I couldn't see inside the Joomla editor where I could change the font or colour formatting of paragraphs or words
I did a search for this (using several search words and phrases) and most of the top results came up with information about changing stylesheets and CSS which didn't seem appropriate for this simple task. Finally I came across a link to an article about adding the extended capabilities to the Joomla editor. Now this was after I had already started to read about CSS based on the idea that this was where my solution existed and had experienced that "sinking feeling" that it would probably take many hours to understand something that made even a simple article possible. It's amazing that this link didn't come up much higher in the google search results where the top results all talked about CSS. One of the top links on google even stated that the way to do this would be to add an extension which of course if it was really true would lead to more research on "which one" is best.
Now I know that I need to learn about stylesheets and CSS but it was such a relief that I had a simple solution to a simple problem (writing an article and playing with its placement) and could learn the rest a little later.
