Question [RESOLVED] Fatal error: Interface 'iKunena' not found
15 years 11 months ago #76714 by 810
i think you got a missing file or corrupted one.
Please remove kunena, and make sure that all files (when you remove kunena, only files will be removed, not the database) on the ftp are gone : \administrator\components\com_kunena\* and \components\com_kunena\* then install kunena again, please download kunena again.
regards 810
15 years 11 months ago #76716 by TazCook
Okay so do I just open my FTP account and delete the folder "com_kunena" and then re-install the kunena program? thanks for the help by the way everyone, its taking a lot of stress off my back!
15 years 11 months ago #76717 by 810
No, first you go to the backend, extensions-uninstall-components -select kunena and click on uninstall. then check on your ftp the files are gone, then install kunena again.
15 years 11 months ago #76719 by TazCook
I just delted it from my site, and it wasn't on my FTP side so I re-installed it and still i'm seeing error at bottom page
15 years 11 months ago #76720 by 810
can you change my account 810 to an super user, then i will look for you.
regards 810
15 years 11 months ago #76721 by TazCook
wow we need more people like you man!
Consider it done! you have the rights now!
thanks
