Question Forum not working: Fatal error: Call to undefined function KUNENA_get_menu()
16 years 4 weeks ago #68205 by ae3d
sorry Led
thats not so ( having problems running Joomla )
im already running J! on this ssrver for a different client
Its been running fine for about 7+ months
that particular installation is not using Kunena
this is the only one im going to be using Kunena on.
I just did a complete removal and install again and i an on this success screen which reads:
I N S T A L L : Successful
php version: 5.2.14 (Required >= 5.0.3)
mysql version: 5.1.26-rc-5.1.26rc (Required > 4.1.19)
Thank you for using Kunena!
Kunena Forum Component for Joomla! © by www.Kunena.com . All rights reserved.
As a matter of curiosity, what is it that makes you believe this installation was incomplete or unsuccessful per your previous statement?
Im asking because maybe you see something i dont which i should know of when doing these installs
16 years 4 weeks ago #68208 by ae3d
i also wanted to say
when i goto my COMPONENTS after the kunena install
i can click on KUNENA and change its configurations, settings, add forums and so on.
It works
i just cant see it from the front end
16 years 4 weeks ago #68213 by ae3d
ok i went ahead and upgraded my joomla version to 1.5.21
and removed everything Kunena related ( filee, links, folders, and SQL tables )
then i started the install process for Kunena 1.6.0_b3620
Here is what i got
Upon using the UPLOAD feature under INSTALL / UNINSTALL in the backend
i got this screen
1) Select an Installation or Upgrade Option
The Kunena forum has been taken offline.
bla bla bla
i read down the page and i did NOT tell it to use any old information it found from Kunena 5x
instead i told it to
Install Kunena 1.6.0.
which would take NOTHING from old and setup a new forum with sample data
it went through it steps
1. Prepare Installation
2. Extract Component
3. Install Languages
4. Install Plug-ins
5. Update Database
6. Finish Installation
seems like it all checked out
(Im typing this stuff while the install is happening by the way )
Now i see a bunch of "OK" text next to each line of the process
seems like it all checks out so lets click FINISH
ok its working now nad i can see it from thefront end.but it does take a while to load the page
and i see this little box pop up telling its a script is basically taking too long on this page
/plugins/system/mtupgrade/mootools.js:1
mootools? awww what the heck
16 years 4 weeks ago #68215 by ae3d
ok seems like we are getting closer
ill start a new thread with the mos recent strange thing happening since this one no lnoger applies to it
