- Thank you received: 201
Question Add adbrite ads inside kunena forum
Insert RED code above to message.php from default_ex template.(should be line 99)<td colspan = "2" valign = "top">
<div class = "msgtext"><?php echo $msg_text; ?>
<div style="float:right; width:300px; margin-left:10px;">
<!-- Begin: Message Module Positions -->
<?php
if (JDocumentHTML::countModules('kunena_adbrite_'.$mmm))
<div class = "kunena_adbrite_<?php echo $mmm; ?>">
<?php
$document = &JFactory::getDocument();
$renderer = $document->loadRenderer('modules');
$options = array('style' => 'xhtml');
$position = 'kunena_adbrite_'.$mmm;
echo $renderer->render($position, $options, null);
</div>
<?php
<!-- Finish: Message Module Positions -->
</div>
</div>
<?php
if (!isset($msg_closed))
Then create new module in joomla backend, in text area insert your code from Adbrite and publish that module in position "kunena_adbrite_1" and adbrite ads will appear in all topics first messages.
Regards
- cinemagrounds
I added the code in red,to messgae.php file.
Created a new position in templatedetails.xml, with title kunena_adbrite1
so far so good.
I also created new module, of type Custom HTML, but seems like HTML editor is removing all the code of adbrite. only the code shown in red is visible.
I also tired to enter this text as plain text, but it didnt work.
<!-- Begin: AdBrite, Generated: 2010-07-23 23:27:02 --><div><a target="_top" href=" www.adbrite.com/mb/commerce/purchase_for...=1702810&afsid=1 " style="font-weight: bold; font-family: Arial; font-size: 13px;">Your Ad Here
this is original adbrite code:
<script type="text/javascript">
var AdBrite_Title_Color = '0000FF';
var AdBrite_Text_Color = '000000';
var AdBrite_Background_Color = 'FFFFFF';
var AdBrite_Border_Color = 'CCCCCC';
var AdBrite_URL_Color = '008000';
try{var AdBrite_Iframe=window.top!=window.self?2:1;var AdBrite_Referrer=document.referrer==''?document.location:document.referrer;AdBrite_Referrer=encodeURIComponent(AdBrite_Referrer);}catch(e){var AdBrite_Iframe='';var AdBrite_Referrer='';}
</script>
<script type="text/javascript">document.write(String.fromCharCode(60,83,67,82,73,80,84));document.write(' src=" ads.adbrite.com/mb/text_group.php?sid=17...='+AdBrite_Referrer+ '" type="text/javascript">');document.write(String.fromCharCode(60,47,83,67,82,73,80,84,62));
<div><a target="_top" href=" www.adbrite.com/mb/commerce/purchase_for...opid=1702810&afsid=1 " style="font-weight:bold;font-family:Arial;font-size:13px;">Your Ad Here
<!-- End: AdBrite -->
the screen now appers like this:
cinemagrounds.com/index.php/forum/News/2...n-attacks-a-Man.html
Is there any specific type module that i need to create for this.
After saving you module you can enable editor in joomla config.
Regards
- cinemagrounds
Your solution worked like a charm !!!!
I now get ads on first post on of any thread..that serves the purpose....
Thankyou every much !!!!
