Question Add adbrite ads inside kunena forum
  • cinemagrounds
  • cinemagrounds's Avatar Topic Author
  • New Member
  • New Member
16 years 4 months ago - 16 years 4 months ago #53280 by cinemagrounds
Add adbrite ads inside kunena forum was created by cinemagrounds
I am trying to add adbrite ads in between the post and its replies. Earlier i was successful in getting the google ads displayed, however whenever google ad doesnt get displayed i want the adbrite ad to be displayed.
My website is:
www.cinemagrounds.com
How can i achieve this.
Earlier, i achieved this by adding the following code in view.php file of the template.
// Google AdSense ---> start
if ( $mmm == 1 ) {
echo '<div align="center">'."\n";
echo '<script type="text/javascript"><!--' . "\n";
echo 'google_ad_client = "pub-5023421363133063";' . "\n";
echo "/* my second ad link unit 120x90, created 4/22/10 */\n";
echo 'google_ad_slot = "0632638656";' . "\n";
echo "google_ad_width = 468;\n";
echo "google_ad_height = 60;\n";
echo "//-->\n";
echo "</script>\n";
echo '<script type="text/javascript"' . "\n";
echo 'src=" pagead2.googlesyndication.com/pagead/show_ads.js ">' . "\n";
echo "</script>\n";
echo "</div>\n";
// Google AdSense ---> end
Now i want to add adbrite code to the kunena forum, how can i do this:
Here is the ad code that i got from Adbrite:
<!-- Begin: AdBrite, Generated: 2010-07-20 20:20:24 -->
var AdBrite_Title_Color = '0000FF';
var AdBrite_Text_Color = '000000';
var AdBrite_Background_Color = 'FFFFFF';
var AdBrite_Border_Color = 'CCCCCC';
var AdBrite_URL_Color = '008000';
try{var AdBrite_Iframe=window.top!=window.self?2:1;var AdBrite_Referrer=document.referrer==''?document.location:document.referrer;AdBrite_Referrer=encodeURIComponent(AdBrite_Referrer);}catch(e){var AdBrite_Iframe='';var AdBrite_Referrer='';}
</script>
<script type="text/javascript">document.write(String.fromCharCode(60,83,67,82,73,80,84));document.write(' src=" ads.adbrite.com/mb/text_group.php?sid=17...='+AdBrite_Referrer+ '" type="text/javascript">');document.write(String.fromCharCode(60,47,83,67,82,73,80,84,62));</script>
<div><a target="_top" href=" www.adbrite.com/mb/commerce/purchase_for...opid=1702810&afsid=1 " style="font-weight:bold;font-family:Arial;font-size:13px;">Your Ad Here</a></div>
<!-- End: AdBrite -->
Last edit: 16 years 4 months ago by cinemagrounds.
16 years 4 months ago #53310 by @quila
have you read our documentation about this docs.kunena.com/index.php/Module_Positions
you can do that without modifing core Kunena file. You need to create new modules in Joomla backend and publish them in the positions you see in our doc. kunena_msg_1, kunena_msg_2 ...
Regards
The following user(s) said Thank You: cinemagrounds
  • cinemagrounds
  • New Member
  • New Member
16 years 4 months ago #53363 by cinemagrounds
Replied by cinemagrounds on topic Re: Add adbrite ads inside kunena forum
Thankyou for your reply.
Yes i Did see that document. If you see my website, i have used the same concept to place google ads to the left side of the template. (Goggle ads to left of the template). Also the template i have used is a free template that has positions only at the left.
however What i am trying now, is to get the adbrite ads inside Kunena forum article itself.
What I mean here , once I post of article, I want adbrite ad to appear within the article itself.
Is that possible.
for example: Look at this article in the following link, where they have done this:
www.dentalforum.com/forum/showthread.php?t=5565
here in this article, they have article and to the right side it also shows the google ads. Instad of google ads i want adbrite ads to appear. What would be the syntax for that and where would i place such a code.
16 years 4 months ago #53370 by @quila
now I understnd what you want to do, this is doable with little change in code but question is: You want to show these ads only in first post or in all posts(reply also)? You can add google ads only 3 per page (dont know for adbrite), if you have Topic with 10 replay per page there will be 10 ads??
  • cinemagrounds
  • New Member
  • New Member
16 years 4 months ago #53388 by cinemagrounds
For now i would like to have the ads,..coming only on the first post of the article...
would like to see them all over the page. this way my page will still look good and will be accroding to the standards of google adsense.
i thought google adsense allowas 3 ad units and 3 link units on each page...
adbrite allows 3 ad units per page..
Basically, i am fresher. I am just exploring on this things. This is what i have understood reading online about adsense and abrite ads...
  • cinemagrounds
  • New Member
  • New Member
16 years 4 months ago #53568 by cinemagrounds
WILL I HAVE TO DO BIG CODE CHANGE FOR THIS....
