Loved how to show selected categories of forum
My sir has said me to accomplish the task first on local machine then onlu to upload on server, plze sir try to contact with other members if they can help
2. I don't think you can create a menu link, in Joomla, that will point your users to "all categories of my Kunena forum except for one category." I assume this is what you want to do. I am sorry that I do not have an answer, but maybe someone else can help.
1. Please use K 1.5.12 because it fixed the deprecated PHP matters. WAMP is not a truly reliable way to develop websites. WAMP can help but it sometimes it is misleading. I recommend that you set up a development or test site on the server you will be using in production.
wamp/xamp and alike are useless for testing advance php sites they cause more issues than they are worth i agree with sozzled create a TEST section on your production server using seperate location ( yourdomain/test/ ) and a seperate database ( test.db ) under phpmyadmin, and then try and test your new setup.
correct this is NOT possible with just a menu link you would have to HACK the kunena catlist and create a version that did not show the announcements catagory, even then im not sure if it would work as you still use that catagory from another link.
A very good evening(Acc. to Indian Standard Time),well can u let me 9 that what other forum component i can use with kunena, so that i can have link to both of my menus i.e, let announcements menu will reffer to all categories shown into "kunena"
& massage board menu will reffer to "fireboard"
but i 9 that we cant use fireboard and kunena altogether into 1 joomla website, but can u recommend me to use any other component which can be used along with "kunena"
I have rephrased your question a little differently. Basically, your questions are totally concerned with how you would like to set up your Joomla menu.Can you [advise] what other [forum] component I can use with Kunena, so that I can have ... [two menu items] i.e. [one that links to an] "Announcements" [category] ... and [the other that links to the broader] "Message Board"
Part of our problem is understanding why you (or anyone) would want two, totally separate, forums running on the one website. So, let's look at the reason you might possibly want to do this.
If your "Announcements" area (births, deaths, marriages, classified advertisements, etc.) is only for placing notices by you then there are other alternatives to using a forum. But, even if this "announcements" area is merely for posting notices and not (as I suspect) for discussions, there are still other ways of doing this that don't involve Kunena. There are other components in the Joomla Extension Directory that handle "listings".
But, even if you want your users to post their own "announcements" topics and you also want broader discussions to take place, there's another way to help your users find where they can do these things. When you get right down to it, that's all that a menu does: helps your users find where they can get in touch with the services that your site provides for them.
So, let's look at your requirement in a slightly different way. You want to show your users that they can post "announcements" and you also want to show that your site also has a general "message board". One, very easy and highly effective way you can do this is to use Kunena, as you have already set it up right now, with one section for "announcements" and another section (or sections) relating to other matters ... but, if you asked me to implement the solution, I would definitely not create two, discrete and separate, menu items. I would create, instead, one menu item and I would label it "Announcements and Message Board".
I would make one menu item "Announcements and Message Board" and I would link it to my Kunena forum. When my users arrived at my Kunena forum they would see the different sections (one for "announcements" and the other(s) for more general messages) and use them accordingly. If my users had trouble deciding where to post their messages, I would provide them with other help. I would write descriptions in the categories or create "sticky" posts, just like we do here at Kunena.com.
It's really not such a big deal: Kunena can do everything you want. Perhaps, if you look at what you're trying to achieve in a different way, you will see that there are other, simple and non-technical solutions that are just as effective as the one that you're trying to implement. I hope that my suggestion solves your problem. I really don't think the solution lies in worrying about how to create two separate Joomla menu items or worrying how to resolve the hyperlinks.
