Question I want more than one adsence on my forum
The ads are squashed up against the topic windows and my 'quick reply', 'quote', 'edit' etc. buttons half dissapear 'behind' the topic window.. Any sugestions?
would this be edited in a CSS file somewhere?
Thank you in advance.
ukeboards.com/
if custome HTML doesn't work. use the method above
I was hoping someone could help me. I am trying to install Google adsense module into my Kunena forum, that I am using with Joomla's JA_Purity template, but can not seem to get the ads to show in between threads. I was refered to you from exinkai.com after trying thier implementation tutorial at:-
www.exinkai.com/index.php?option=com_kun...view&catid=10&id=486
I have also tried another tutorial at joomla-R-us.com:-
joomla-r-us.com/tutorials/37-joomlatutor...-inside-kunena-forum
where they say to add the ad code into the view.php file, however, the code in my view.php is slightly different to that of the tutorial view.php file. I did try it anyway but to no success.
Any help would be much appreciated.
ukeboards.com/
www.exinkai.com/index.php?option=com_kun...iew&catid=10&id=1074
this may help you
