Sticky How to protect my forum from spam
14 years 8 months ago #116195 by Groenteman
I found many post about spam but not one real solution.
It would be a big help to block guest posts with links, url's, href
So when a guest writes a post and in it is a link, url ...
then don't allow the post.
Is this a lot of code? where to put this hack?
Thanks in advance.
14 years 8 months ago #116519 by FAN
I want to add CAPTCHA to the registration to prevent spammers from getting to the forum. I'm a little confused because Kunena also uses parts of Joomla (users). So... can I add captcha to Joomla registration by finding a plugin or something that replaces com_users? Or is that a bad thing and will Kunena not work after that? So where should I add CAPTCHA to solve my problem?
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 32M
Joomla default template details : yoo_pure | author: YOOtheme | version: 5.5.11 | creationdate: September 2011
Kunena default template details : Aphotic | author: snilloconator | version: 1.6.0 | creationdate: 2010-23-09
Third-party components: UddeIm 2.6
Third-party SEF components: sh404sef: The file doesn't exist sh404sef.xml !
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.7.1
Modules: Kunena Latest 1.7.1 | Kunena Search 1.7.1
14 years 8 months ago #116521 by Jiminimonka
Yes, if you install a Captcha extension it will work with Joomla and therefore Kunena since the latter uses the former for registration.
RVS reCaptcha is one that I use (with free Google Captcha) and I also have SpambotCheck - you can find them on the Joomla extension website (K!1.7 and J!1.7.3 on my system).
Please read the FAQ.
Only one question per topic.
The following user(s) said Thank You: FAN
14 years 8 months ago #116522 by FAN
It's amazing how fast people respond to questions! Fantastic!!! :woohoo:
14 years 8 months ago #116651 by Jiminimonka
FAN wrote: It's amazing how fast people respond to questions! Fantastic!!! :woohoo:
I just happened to be in the area at the time. ;)
You're welcome!
14 years 8 months ago #116684 by kross76
I just installed this extension, and it works great. The kunena team should take a look at incorporating it into the base system. There are some obvious improvements that it could use, but the basic system is very helful in reducing spam on our forum (which allows guest posts).
Time to create page: 0.275 seconds
