Sticky How to protect my forum from spam
16 years 7 months ago - 16 years 7 months ago #38760 by ajrallen
It is as someone earlier said: this feature only works if you are not logged in. The assumption, I guess, is that if you are a registered user then you can't spam.
At any rate, the offending line is currently in /components/com_kunena/template/default/fb_write.html.php on line 270. It says:
if ($fbConfig->captcha == 1 && $kunena_my->id < 1) ?>
It can be changed to:
if ($fbConfig->captcha == 1) { ?>
Then to make sure that ths code is checked, you need to change line 62 of /components/com_kunena/template/default/post.php from:
if ($fbConfig->captcha== 1 && $kunena_my->id < 1) {
to:
if ($fbConfig->captcha== 1) {
Standard warnings apply: this would be a hack and would be overwritten when you upgrade Kunena.
Kunena Developers: Ideally the config option would be changed to a three-value list:
0=Never use Captch
1=Use Captcha when users are not logged in
2=Always use Captcha
Last edit: 16 years 7 months ago by ajrallen. Reason: forgot part of the fix
16 years 7 months ago #38761 by sozzled
It's always a dangerous thing resurrecting a discussion topic that began 9 months ago but which dried up 3 months ago. :laugh: A lot has happened. :blush:
See also Replace captcha with reCaptcha for some more up-to-date views on this subject. ;)
16 years 7 months ago #38765 by ajrallen
Well, that's what I get I guess. I often use advice I find on message boards but never contribute. I finally contributed, and I should have kept my mouth shut.
Of course, the version that I am using that doesn't have a working Captcha feature in it was downloaded only about 2 weeks ago and the post you mentioned was only 3 days old, so the "lot" that has happened has not changed this, yet. And will using reCaptcha change the way the config works?
16 years 7 months ago #38767 by sozzled
A lot has changed. The topic I referred to (that's 3 days old) is only the latest in a long list of topics about CAPTCHA and Kunena and spam protection. I should also have added a thank-you for taking the trouble to investigate the inner workings of Kunena and I apologise for my flippancy. Even so, it's still a dangerous thing to take an old issue like this - (I was a novice when I posted my original question 9 months ago :blush:) - and try to make it relevant today. In the past 9 months, there have been 11 public releases of Kunena ... so a lot has happened!
Please understand, your discoveries and your opinions are important to us. :)
16 years 7 months ago #39913 by AdamFL
Hello -
First thank you all for the great forum software. I run many forums and mainly vBulletin however I just set up a website with kunena and loving it.
The website and forum are new (one week old) and I'm getting daily registrations and posts (spam).
My question is what options this software offer to fight spam, automated registration bots, etc. Is there any recaptcha at the registration process? Any tips tricks are really appreciated because I dont have time to keep up with this bots (assuming) and delete posts manually.
Thank you for your time and help.
16 years 7 months ago - 16 years 7 months ago #39915 by LittleJohn
Hello
The registration and login process is handled by Joomla. You might want to look for some extensions in the Joomla Extensions for that.
Please beware, that you cannot seek help for those extensions here.
I found this at my first search: extensions.joomla.org/extensions/access-...authentication/10802
Also, Kunena has some captcha service in the administrator panel, which can easily be turned on.
I think it goes under the name "Antiflood protection" but I really cant remember.
Some of these features (maybe combined), may be what you are looking for?
Last edit: 16 years 7 months ago by LittleJohn.
Time to create page: 0.352 seconds
