Sticky How to protect my forum from spam
14 years 3 months ago #116651 by Jiminimonka
FAN wrote: It's amazing how fast people respond to questions! Fantastic!!! :woohoo:
I just happened to be in the area at the time. ;)
You're welcome!
Please read the FAQ.
Only one question per topic.
14 years 3 months ago #116684 by kross76
I just installed this extension, and it works great. The kunena team should take a look at incorporating it into the base system. There are some obvious improvements that it could use, but the basic system is very helful in reducing spam on our forum (which allows guest posts).
14 years 3 months ago #116714 by Jiminimonka
kross76 wrote: I just installed this extension, and it works great. The kunena team should take a look at incorporating it into the base system. There are some obvious improvements that it could use, but the basic system is very helful in reducing spam on our forum (which allows guest posts).
Captcha is now part of Joomla 2.5 (turned off by default).
14 years 3 months ago #116716 by proterra
sozzled wrote: proterra: I think you have a different problem ( Spamschutz: Captcha zu schwach ). Please use your own topic or create a new topic, in English, in Kunena Discuss (P) . Make sure you are using the latest version of Kunena and Kunena Discuss plugin and post your configuration report. I think we can help you better if you do that.
No the problem is that guest can post a captcha code (in the forum and the discuss plugin) they want.
Test it on 3 different sites.
14 years 3 months ago #116953 by MonkeyDragon
Replied by MonkeyDragon on topic Banning IP's?
Hello all......apologies if this has already been covered elsewhere but I have had no luck in finding the info after a while of trawling through old posts.
I am running version 1.6.0-RC1 but have had to disable registration as the site keeps being invaded by spammers - the vast majority iof which are from the same three IP Addresses. Sometimes they post dozens of pointless topics (mainly a 'company' called AderisPharm) and occassionly it's some weird morbid stuff about child abuse and suicide....all very odd and as you know, extremely disruptive.
I can not see any option to either ban IP Addresses or to activate some kind of filter, eg: Admin needs to authenticate a user/email address prior to them being allowed to commence posting, require a code to be entered etc Do these options exist and if so, where? Failing that, would it require that I load a different version?
The last option then opens up a whole can or wroms though as I am trying to keep expenditure to a minimum having been ripped off to the tune of a few thousand pounds by a rather scrupilous company who I commissoned to originally build the site. Is it easy to upgrade the current version of would it require a proffessional as I'm keen to not lose the posings currently on the forums?
Many thanks in advance and keep up the good work all - this forum is a very valuable tool, so much appreciated.
14 years 3 months ago #116955 by CheechDogg
Replied by CheechDogg on topic Re: Banning IP's?
Hello MonkeyDragon and welcome to Kunena.org my Friend.
There are actually many ways you can block IPs from accessing your website, but the best way to do so is by using the "deny from xx.xx.xxx.x/xx" in your .htaccess file.
If you know how to do this you can greatly reduce the amount of spammers accessing your forums. Another way is to use anyone of these extensions:
extensions.joomla.org/extensions/access-...e-access/ip-blocking
Another way is to also add a "CAPTCHA" program during registration. This is through your joomla registration though and I personally use Alpha Registration .
Visit those sites and check them out, if you need any help installing them or with the .htaccess file let me know and I will gladly help you.
[img
Find me on Facebook.
Time to create page: 0.290 seconds
