Question Avatars not loading Kunena 5.1.19 Joomla 3.9.22
5 years 5 months ago #214468 by JC2033
Hi folks, New to Kuena. I'm Looking for help on this issue of Avatars not loading. I have googled extensively and searched the forum and checked the permissions and settings suggested. Not sure where to go next. Appreciate any suggestions.Running Joomla 3.9.22. Thanks in advance.
5 years 5 months ago #214469 by rich
With this information I can only guess. Go in the backend to Kunena -> Plugins and disable the Gravatar plugin.
If you have more questions, please add also a configuration report: docs.kunena.org/en/faq/configuration-report
5 years 5 months ago #214483 by JC2033
Thank you for your response and request for more information. Sorry I did not know how to provide that. I can confirm that the Gravatars plugin is disabled. Thanks for your help.
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 640M | Max file upload: 300M
Joomla default template details : shaper_helix3 | author: JoomShaper.com | version: 2.5.6 | creationdate: Jan 2016
Kunena default template details : NTS KSumo | author: Nice Theme Store | version: 1.0.0 | creationdate: 2020-06-07
Kunena template params:
Kunena version detailed: Kunena 5.1.19 | 2020-08-15 [ Tethys ]
Plugins: None
5 years 5 months ago #214484 by JC2033
Hi Folks, some further info. I managed to check the FTP permissions (See attached pic). File path web/plugins/kuena/avatars. Avatar folder is empty and is 0755. Only the owner has write permissions do others need write permissions? What is slightly unexpected is that when I continue on that file path: web/plugins/kuena/avatars/......gallery/users, I cannot select gallery/users or their subfolders to make them show in the right hand pain (where I have options to upload / edit etc) Is that because all those folders are empty. If I could select them then I presume I could upload images....however the solution I am looking for is that members can upload there own images. Thanks for you help.
Mods (I am on an unstable connection if this duplicated please delete this post) - Thanks
Attachment not found
5 years 5 months ago #214487 by rich
You have disabled "Allow Avatar Upload" in your Kunena configuration. Configuration -> tab Avatars -> Allow Avatar Upload must be Yes
5 years 5 months ago #214488 by JC2033
Hi Rich, I appreciate your help. Can you check this screenshot I understand that upload is set to yes. As an aside I have a number of other issues and wondered if I should try reloading. I can't update the date in my profile or post a topic I get a Unclosed string at position: 2784 error. Happy to keep persisting but just thought id mention. Cheers.
Time to create page: 0.282 seconds
