Solved Notification emails dont work right!
13 years 3 weeks ago #150096 by eJuiceVaporz
I have put in my email i want kunena to send notifications to when users post on my forum and every time kunena keeps sending emails to all my other emails then the one specified in the kunena settings.
Why is this ?
I use Joomla 2.5.14 & kunena 3.0.3
I have also had this issue in earlier versions of kunena and in every version the kunena developers don't fix this problem which is driving me totally nuts o.0
Can someone please tell me if there is a work around this annoying bug ?
13 years 3 weeks ago #150112 by sozzled
G'day, eJuiceVaporz, and welcome.
eJuiceVaporz wrote: I have also had this issue in earlier versions of kunena and in every version the kunena developers don't fix this problem which is driving me totally nuts ...
Did you report this problem before (in the earlier versions of Kunena that you were using)?
It may help to read the information printed at the top of this page that may help us to help you resolve this problem quicker - there is information posted at the top of this page that will point you in that direction (to help us know more about your site so that we can help you better); this information is printed in dark, bold, italicised font . This is what I mean:
If you are using the forum to discuss your problems then, for your own benefit, it would save us all a lot of time if you would kindly post your configuration report when you ask for help. If you do not post your configuration report we will not ask you for it but you may not receive a solution to your problem, either.
The following user(s) said Thank You: eJuiceVaporz
13 years 3 weeks ago - 13 years 3 weeks ago #150114 by eJuiceVaporz
Sorry and thanks for the pointer.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 32M | Max file upload: 2M
Joomla default template details : gk_bikestore | author: GavickPro | version: 3.3 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Plugins: None
Modules: Kunena Login 3.0.1
Last edit: 13 years 3 weeks ago by sozzled. Reason: Remove spoiler from configuration report
13 years 3 weeks ago #150117 by sozzled
Thank you for your configuration report and for showing us the forum sending email address (which was going to be my next question).
Theoretically, you can have a different email address (from your main site email address) which is used when sending notifications (e.g subscriptions and notices to administrators and moderators - if you want).
In your case you have set your configuration so that
E-mail Moderators = Unapproved posts
E-mail Administrators = Unapproved posts
Email about "unapproved" posts is sent if you have categories where you have Review Posts = Yes
If you want to be notified about all messages, change
Forum Configuration » Security » Security Settings » E-mail Moderators = All new posts
Forum Configuration » Security » Security Settings » E-mail Administrators = All new posts
Try that first and tell us if it has made a difference.
As far as where the email is "categorised" in your inbox (you say that you have mail that "doesn't belong") that's something you have to configure in your email client program. What email client software are you using?
13 years 3 weeks ago - 13 years 3 weeks ago #150118 by eJuiceVaporz
oh ok and thanks for the help.
I dont know what i am using. As soon as i paid my web developer he stopped working on my site and dumped an empty web site of to me and i had to spend 3 months building up this website and it had lots of errors where i asked in the joomla & virtuemart forums but the involvement there isn't noob friendly at all but i managed to get it all sorted out on my own. Now my last problem is the email notification from forum.
All i know is that i use something called C-Panel if that rings any bells ?
I'll just go now and see if i can find out what email client C-Panel uses.
Which one should i click to find out about the email client ?
Ok nvm i found this part under webmail.
After clicking configure mail client i get this up and now i am confused o.0
but i changed that a while back to :
So i dont understand why the configuration report said ?
Last edit: 13 years 3 weeks ago by eJuiceVaporz.
13 years 3 weeks ago #150124 by sozzled
My apologies. My eyesight is not too good first thing in the morning :D
Forget what I wrote about [about what I thought were] your email settings. This only proves that I don't know how to interpret a configuration report very well :blush: ... sometimes. ;)
Getting back to your problem - which you say you've had in earlier versions (but haven't talked to us about before) that the Kunena developers have not fixed (which may or may not be true, I don't know):
Let me go through the process as I understand things are happening [wrongly] for you.
You have a Kunena forum and you expect to receive a notification by email of every new message posted on it. This process seems to be working, is that correct? Every time a new message is posted on your forum you get an email saying "you have a new message posted on your forum". Have I got the picture right up to this point?
You have defined your Joomla site to use its mail address as something like "info@domainname" and your Kunena forum mail address is "forum@domainname". Have I got things right so far?
The email you get, when new messages are posted on your forum is generated from which address? The "info@" or "forum@" address?
We'll turn our attention to the matter of how incoming mail is categorised by your email client software in a short time after I have confirmed my understanding of analysing the situation as things now stand.
Time to create page: 0.171 seconds
