Question Installation Problems in sub-web
It is both configuration.php files that have permissions set at 444 instead of the usual 644 setting for files.
- Thank you received: 2545
It's ok.It is both configuration.php files that have permissions set at 444 instead of the usual 644 setting for files.
Please try following:
1. Download Kunena and unzip the package
2. Upload the folder via ftp in the tmp folder "jupgrade/tmp"
3. Install from Directory
Moving along to your current instructions, When I unzip the download, there are 5 individual files and a folder named "packages" containing 5 zip files.
The default install directory in the .../jupgrade Extension Manager is: /hermes/bosweb26a/b169/ipw.johnharper/public_html/tmp. (I assume that came from my host).
Note that it points to ...public_html/tmp, NOT public_html/jupgrade/tmp. Should I change it?
Thank you for your patience and prompt replies. I'll buy you a beer or two when we get done.
1. Go to your main Joomla directory, and open the configuration.php.
2. Notice the path to the folder "tmp".
3. Go to in the folder jupgrade.
4. Open the configuration.php.
5. Check if it is the same path.
6. If it's the same, then expand this path with "jupgrade"
from
path/path/path/tmp
to
path/path/path/jupgrade/tmp
thats all
If you unzip the package, then you have a folder with content.When I unzip the download, there are 5 individual files and a folder named "packages" containing 5 zip files.
Or are we still working on trying to do an "Install from Directory" procedure?
If it doesn't work, I do not know how I can help you more.
