Question Installation Problems in sub-web
13 years 5 months ago #144506 by TwoHoot
I am upgrading a Joomla 1.5 website to Joomla 2.5. I used Jupgrade to do it. It created a new sub-web at jcharper.net/jupgrade where I am rebuilding it. The first extension I need is Kunena Forum with the Discussion add-on.
When I try to install it form the jcharper.net/jupgrade adm panel, I get the following error messaage:
"Error connecting to the server: failed to open stream: no suitable wrapper could be found Invalid URL"
Is that because I am not installing in the root directory or is there something else wrong?
Please Advise.
Cordially,
TwoHoot
I tried to post this a short while ago and got sent through a couple of captchas for some reason. What is going on?
13 years 5 months ago #144512 by Mortti
Is it that when you are migraded from J! 1.5.XX (main domain) to J! 2.5.xx and you can not install Kunena in subdomain www.maindomain/jupgrade Did I understand right?
The following user(s) said Thank You: TwoHoot
13 years 5 months ago #144513 by TwoHoot
Yes, that is correct. The old site did not have a forum. I am trying to install Kunena 3.0 to the mydomain/jupgrade using the URL procedure recommended.
13 years 5 months ago #144516 by rich
Actually, it should work. Please, check the configuration.php in the folder jUpgrade if the tmp path is correct.
public $tmp_path = '/.../jupgrade/tmp';
13 years 5 months ago #144519 by TwoHoot
It is not. Neither is the Log file. they are set to ... public_html/tmp - the root tmp file
In fact, there is nothing in the .../jupgrade/configuration.php that mentions ... /jupgrade
Also, I notice that permissions are set to 444. Is that correct?
13 years 5 months ago - 13 years 5 months ago #144520 by rich
Correctly ist chmod 755 for the tmp folder. With chmod 444 can the package not be uploaded.
Last edit: 13 years 5 months ago by rich.
