Solved Login Problem
13 years 7 months ago #139988 by ivantee
Replied by ivantee on topic Login Problem
sozzled wrote: I do not understand what you mean by
ivantee wrote:
I cannot access the standard module Joomla
What did you do with it?
The login does not work from standard form joomla :(
Is the form in the lower left corner of the site (I have enabled today so you see it)
sozzled wrote: A suggestion: try using the K 2.0 Blue Eagle template instead of the one designed for K 1.7.2 ... and try using the normal, default Kunena menu instead of your customised one.
Ok, I have changed the template.
Which is the default menu of the kunena's forum?
13 years 7 months ago #139997 by Jiminimonka
Replied by Jiminimonka on topic Login Problem
I tried logging in with the login module and with the kunena login, neither worked. You have something configured wrongly in Joomla, this is not a Kunena issue.
Please read the FAQ.
Only one question per topic.
The following user(s) said Thank You: ivantee
13 years 7 months ago - 13 years 7 months ago #140006 by ivantee
Jiminimonka wrote: I tried logging in with the login module and with the kunena login, neither worked. You have something configured wrongly in Joomla, this is not a Kunena issue.
We have the same idea for the resolution of the problem but Everything's happen after the registration of the spammers, so i have deleted them also from DB, but the problem is not solved.
Please can you show me the right way to the resolution of my problem please?
Thank you all :blush:
PS: The site exist since one year and I never changed the configuration, but the forum doesn't work since january the first 2013.
Last edit: 13 years 7 months ago by ivantee.
13 years 7 months ago - 13 years 7 months ago #140011 by sozzled
Replied by sozzled on topic Login Problem
ivantee wrote: Which is the default menu of the kunena's forum?
Please see How do I restore my Kunena menu? This is a frequently asked question.
Last edit: 13 years 7 months ago by sozzled.
13 years 6 months ago #141348 by ivantee
Hello, anybody has a solution in mind?
I'm desperate :(
I apologize for my insistence :(
13 years 6 months ago #141350 by xillibit
Replied by xillibit on topic Login Problem
I advise you to upgrade Joomla! to 2.5.9 if it's not already done.
Time to create page: 0.236 seconds
