Solved Login Problem
13 years 8 months ago - 13 years 8 months ago #139291 by ivantee
Login Problem was created by ivantee
Hello, my name is Ivan and I am an Italian user (sorry for my imperfect English)
I had Kunena 1.7 and I have updated to version 2.0.3
My problem is that I can not just log into the forum, I put user and pass, I click on Login and after loading I always go back to the home of the forum with the message << Welcome Guest >>.
How can I fix? :(
I am using Joomla 2.5.1 and Kunena 2.0.3
If you need I can write website address.
Why the Italian section of the forum is locked?
I apologize if I'm wrong section, ask the moderators please do not close my post.
Last edit: 13 years 8 months ago by ivantee.
13 years 7 months ago #139657 by ivantee
Replied by ivantee on topic Login Problem
Nothing answers? :(
13 years 7 months ago - 13 years 7 months ago #139658 by sozzled
Replied by sozzled on topic Login Problem
K 2.0.3 is not supported. Please upgrade to K 2.0.4 and see if this fixes your problem. If this does not fix your problem, please read the important information - see Please read this first posted at the top of this page - and post your configuration report here.
This category is locked because we do not have someone who speaks/writes Italian who is able to moderate the category for you. If there is someone, experiences in forum moderation, who speaks/writes Italian, who would like to join the Kunena team to help with questions written in Italian, then we will unlock that category. Until that time comes, the category will remain locked.
Last edit: 13 years 7 months ago by sozzled.
The following user(s) said Thank You: ivantee
13 years 7 months ago - 13 years 7 months ago #139862 by ivantee
Thanks for your reply.
I think it's a problem of joomla because I can not access the default module joomla.
How is it that the login works day in and day out?
It is possible that I passed a connection limit or something?
Could you please help me? I hope soon to upgrade Kunena.
Best regards
EDIT: I have updated the forum to the version 2.0.4 and I can not log in to the forum :(
Last edit: 13 years 7 months ago by ivantee.
13 years 7 months ago #139898 by ivantee
My configuration:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 64M | Max file upload: 2M
Joomla default template details : siteground-cityview | author: SiteGround | version: 1.0.0 | creationdate: 17 May 2011
Plugins: None
Modules: Kunena Login 2.0.4
13 years 7 months ago - 13 years 7 months ago #139927 by sozzled
I do not understand what you mean by
ivantee wrote:
I cannot access the standard module Joomla
What did you do with it?
A suggestion: try using the K 2.0 Blue Eagle template instead of the one designed for K 1.7.2 ... and try using the normal, default Kunena menu instead of your customised one.
Time to create page: 0.258 seconds
