Kunena 7.0.8 Released
Solved J! 2.5.7 + K 2.0.2 + shape5_vertex template -> cookie problems
13 years 9 months ago #135572 by WhatNoWebsite
HI
To see how many cookies are generated there are a number of add-ons available for Firefox or you can inject PHP code into the footer of the template that displays them.
PHP can generate both client and server side cookies.
The BAD REQUEST is a real difficult one to replicate and the only way we have managed to do it is by turning on SEF & Mod Rewrite and hitting as many pages as possible on the forum, eventually it occurs. (not very scientific but works).
I think what we'll have to do is copy the website to another domain, turn it off in global config and test there.
I'll PM you with a login if you like...
13 years 9 months ago #135760 by oldfart
Some humble pie ....
we have found what is causing the problem. You were quite correct - the template. We found the fix here
_http://www.shape5.com/component/option,com_smf/Itemid,75/topic,21079.msg83472/#msg83472
13 years 9 months ago - 13 years 9 months ago #135761 by sozzled
I seem to recall writing
sozzled wrote: We have received many reports (not good ones) about Shape5 templates.
I think we can chalk this one up as another one of those.
This is why it's critical, when we're doing problem analysis, to eliminate all these extraneous factors and, in keeping with the principles of the When all else fails, try this approach, to use test on a clean Joomla site with nothing else added; especially not a third-party template.
I am pleased your problem has been resolved. :)
Last edit: 13 years 9 months ago by sozzled.
13 years 9 months ago #135770 by WhatNoWebsite
We are also.
Thanks for your patience...
