Important [Resolved] Moved site: forum post contents disappeared
14 years 8 months ago #120992 by Xamb
This is serious, please help me !!
I just migrate all my joomla site to a new host.... ,i made a back up of all the sql tables of the kunena, and reinstalled in the new host.... i did like this twice, but this time the users posts have dissapear.... it shows the user post but without any information
this is an example link FORUM
Any suggestions??
thanks :blush:
14 years 8 months ago #120995 by sozzled
G'day, Xamb, and welcome to Kunena.
Xamb wrote: I just migrate all my Joomla site to a new host.
Am I correct in assuming that your forum (and everything it contained) was working properly on the old host? What verion of Joomla were you using on the old host and what version of Kunena were you using on the old host?
Xamb wrote: I made a back up of all the SQL tables of Kunena, and reinstalled in the new host.
Did you only export the SQL tables from your old host and import them into your new host? What about all the user tables, too, and the message attachments? Did you move those things across as well?
What version of Joomla are you using on the new host? Can you provide us with your Kunena configuration report for your new host?
14 years 8 months ago #120996 by Xamb
thanks for the quick reply.
Here the answers:
1-)in both, i have used joomla 1.5.23
2-)the forum was allright in the old host
3-) I exported and imported old the sql kunena tables and import jos_users, jos_core_acl_aro and jos_core_acl_groups_aro_map, nothing else
4-) in both i have used kinena 1.7
thanks for the help
here´s the kunena report
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : colombian92 | author: Andrés Zambrano | version: 9.2 | creationdate: 2012-03-21
Third-party components: AlphaUserPoints 1.5.13 | Jomsocial 2.6_Strike_RC3
Modules: Kunena Latest 1.7.2
14 years 8 months ago #120999 by sozzled
Please read about Legacy mode .
I do not know anything about Jomsocial 2.6_Strike_RC3; maybe it does not work with K 1.7.2? Maybe it does not work with J! 1.5.25? :dry: Does anyone else know about this?
14 years 8 months ago #121000 by Xamb
in the previous host i had Jomsocial 2.6_Strike_RC3 too, and it worked
14 years 8 months ago #121002 by sozzled
Thanks for that information. Even so, we strongly advise you to disable the System - Legacy plugin on your site. K 1.7.2 has not been tested on J! 1.5 sites with "legacy mode" enabled.
Time to create page: 0.150 seconds
