- Thank you received: 1
Question LaTex implementation for Kunena 1.5.5 ?
One more Question :side:
If i wanna hack the kunena.parser.php for change/add some of the bbcodes for LaTEx (or mimetex) or add some links in there (that it will be showed in the Editor, like "bold", "italic text" etc. Ho do i do that? Ok, i'm a newbie in php but you replace by bbcodes some html-codes, right? Or am I wrong? Please help me!!
The bbcode that you must set before. Its the way how you do it in phpbb3.
And that would be the html-raplacement
if you change the "first" {TEXT} in the code into a "LaTex script" (i'm german, sorry for my bad english) the mimetex.cgi will give you the right output (expression) that you wanted:
The Forum that i wanna install is for educational purpose, thats why i ask :ohmy:
Thank for your help Matias
when i try to upload and overwrite the files, filezilla show me this message:
STOR smile.class.php
550 smile.class.php: Permission denied
Critical Error
You don't have permissions to write on that file. I suppose that it's owned by apache. If you don't have root access, I advice you to turn on FTP mode in Joomla and install Kunena again. It will change permissions to yourself..
Alternatively you can use eXtplorer to keep editing and uploading files with apache permissions.
Also, this topic should probably be merged with:
www.kunena.com/forum/21-language-specifi...ere-else-to-put-this
You might also find inspiration in:
wiki.lyx.org/LyX/InstantPreview
I've reinstalled kunena and now the latex function works fine! Thanks.
But i have now a strange problem... :blink:
When wanna write "\sqrt[3]{x}" (its latex-function) the "3" disappears and kunena shows only "\sqrt{x}"
interprets kunena "[3]" as a bbcode or what's wrong?? :huh:
- chuanhtien
