Question A Bar Problem- Bar not centered
15 years 10 months ago #50962
by neo4evr
A Bar Problem- Bar not centered was created by neo4evr
15 years 10 months ago #50963
Replied by sozzled on topic Re: A Bar Problem- Bar not centered
This is very surprising! There was
a problem with K 1.5.11
but it was supposed to be fixed in K 1.5.12 (as you can see on this website). So, I have to ask , what template are you using with your version?
Have you seen Kunena 1.5 template compatibility ? :dry:
15 years 10 months ago #50964
by neo4evr
Replied by neo4evr on topic Re: A Bar Problem- Bar not centered
Yes previously i also saw this website had the left alignment fault but is now fixed!
Why does this happen with me. I am using the default_ex template only.
Okay, i uninstalled Kunena 1.5.11 and installed 1.5.12 as the update method. After that, i did not change anything in the configuration. Do i have to edit anything? I also tried the code you wrote in that thread but there but it is covering the whole span of the box. Looks better ....
But i am not getting the centered thing.
Please please help
Please please help
15 years 10 months ago #50965
Well, you may have found a defect! I just tried the K 1.5.12 installation on a test site and, yes, the graph is left-justified! The link in my previous messages shows you how to work around the problem.
15 years 10 months ago #50967
by neo4evr
15 years 10 months ago #50969
Let's wait until I can get a few other people to look at this, OK?
Time to create page: 0.235 seconds
