- Thank you received: 5
Question Posts Bar on Kunena Site is left-aligned in Firefox
- joomlauser
- Senior Member
15 years 11 months ago #50290
by joomlauser
Posts Bar on Kunena Site is left-aligned in Firefox was created by joomlauser
15 years 11 months ago #50297
Replied by sozzled on topic Re: Posts Bar on Kunena Site is left-aligned in Firefox
I'm not sure if this is an error or not (yes, I see the same as you do). I find it curious that this "problem" has been in Kunena for such a long time and no-one has commented about it until now.
Perhaps this was not a deliberate mistake but it is possible to centre the graph, if that's what you want. You will need to modify ../components/com_kunea/template/default_ex/view.php at line 713 (assuming that you are using K 1.5.11 and the default_ex template, of course)
Change the 64 to 150 and see if that makes a difference.
$myGraph->SetGraphWidth(64); //should match column width in the <TD> above -5 pixels
15 years 10 months ago #50336
by fxstein
Replied by fxstein on topic Re: Posts Bar on Kunena Site is left-aligned in Firefox
I believe this is due to the rank images missing here on kunena.com
The missing rank images cause various browsers to mess up the alignment. Still looking for a copy of the ones that got installed here a while ago. One of our prior admins uploaded them without ever storing a central copy on the svn or any other location. We either need to recreate them or switch back to the Kunena defaults.
- joomlauser
- Senior Member
15 years 10 months ago - 15 years 10 months ago #50337
by joomlauser
Replied by joomlauser on topic Re: Posts Bar on Kunena Site is left-aligned in Firefox
sozzled wrote:
No I have to do the same with statistic bar from AlphaUserPoint
Thanks, It made a difference. Now it looks much better. Now, statistic bar is stretched beetween edges of table.Change the 64 to 150 and see if that makes a difference.
Last edit: 15 years 10 months ago by sozzled. Reason: very minor change to user's BBcode to improve appearance
15 years 10 months ago #50363
by JoniJnm
Replied by JoniJnm on topic Re: Posts Bar on Kunena Site is left-aligned in Firefox
In lib/kunena.statsbar.php
echo '<div class="viewcover">';
By
echo '<div align="center" style="margin:0 5px">';
By
15 years 7 months ago #63596
by C0n
Replied by C0n on topic Re: Posts Bar on Kunena Site is left-aligned in Firefox
Thanks fixed my issue
Time to create page: 0.244 seconds
