Question Posts in wrong order
16 years 9 months ago - 16 years 9 months ago #38251 by Huan
Posts in wrong order was created by Huan
Hi guys
I've been using kunena from last few months and everything is perfect excluding posts occasionaly appearing in wrong order.
example - audi.blokowisko.civ.pl/index.php?option=...atid=45&id=4239#4434
top one with id name #4412 should appear somewhere at the bottom but somehow is not...
It doesn't happen every time but occasionaly. I've done update to latest version and I thought that you guys fixed that at some point...but you didn't so decided to ask you about some solution...
Thanks! :woohoo:
EDIT
For those who can't view 1st link ... sending another one containing same problem...
audi.blokowisko.civ.pl/index.php?option=...iew&catid=15&id=2420
Last edit: 16 years 9 months ago by Huan.
16 years 9 months ago #38254 by xillibit
Replied by xillibit on topic Re:Posts in wrong order
This may produce because you have merged, a thread into another, if this is that it's a know issue.
16 years 9 months ago #38255 by Huan
Replied by Huan on topic Re:Posts in wrong order
What do you mean by saying "merged a thread into another"? As far as I know someone started new topic...people were answering and then one of answers went on top...
16 years 9 months ago #38256 by xillibit
I would said, when you use the function merge, the order of messages is wrong.
Check, if nobody use the parameter latest post first, maybe this can break the order...
16 years 9 months ago - 16 years 9 months ago #38269 by Huan
all of users use latest posts first option...is there any general setting for this option? or should I go through every single account and change it? and how to set older posts first as default?
EDIT:
...just checked with default template and don't have this problem...so probably there is something wrong with default_gray one...
16 years 9 months ago #38276 by xillibit
