Question category recount problem, duplicated posts
16 years 11 months ago #35686 by Matias
I do not see any problem. All the threads have correct number of replies in them.
Did you get this issue fixed and if you did, how?
16 years 10 months ago #37021 by laoneo1
I reverted back to the database state before I run the recount function....since then I haven't recounted the category stats. another problem which appeared with the mogration to 1.5.8 was that when I move a thread the last post field of the old category still shows the moved thread as its last post...
I think something is broken in kunena since version 1.5.7 which was working perfectly....
16 years 10 months ago - 16 years 10 months ago #37350 by LOK
I had the same problem (dublicate Threads)... I was able to fix it
by removing dublicate user entrys from fb_users and running
ALTER TABLE `jos_fb_announcement` ADD PRIMARY KEY ( `id` ) ; ALTER TABLE `jos_fb_attachments` ADD INDEX `mesid` ( `mesid` ) ; ALTER TABLE `jos_fb_categories` ADD PRIMARY KEY ( `id` ) ; ALTER TABLE `jos_fb_categories` ADD INDEX `parent` ( `parent` ) ; ALTER TABLE `jos_fb_categories` ADD INDEX `published_pubaccess_id` ( `published` , `pub_access` , `id` ) ; ALTER TABLE `jos_fb_categories` ADD INDEX `msg_id` ( `id_last_msg` ) ; ALTER TABLE `jos_fb_favorites` ADD UNIQUE `thread` ( `thread` , `userid` ) ; ALTER TABLE `jos_fb_favorites` ADD INDEX `userid` ( `userid` ) ; ALTER TABLE `jos_fb_messages` ADD PRIMARY KEY ( `id` ) ; ALTER TABLE `jos_fb_messages` ADD INDEX `thread` ( `thread` ) ; ALTER TABLE `jos_fb_messages` ADD INDEX `parent` ( `parent` ) ; ALTER TABLE `jos_fb_messages` ADD INDEX `catid` ( `catid` ) ; ALTER TABLE `jos_fb_messages` ADD INDEX `ip` ( `ip` ) ; ALTER TABLE `jos_fb_messages` ADD INDEX `ip` ( `userid` ) ; ALTER TABLE `jos_fb_messages` ADD INDEX `ip` ( `time` ) ; ALTER TABLE `jos_fb_messages` ADD INDEX `ip` ( `locked` ) ; ALTER TABLE `jos_fb_messages` ADD INDEX `hold_time` ( `hold` , `time` ) ; ALTER TABLE `jos_fb_messages` ADD INDEX `parent_hits` ( `parent` , `hits` ) ; ALTER TABLE `jos_fb_messages_text` ADD PRIMARY KEY ( `mesid` ) ; ALTER TABLE `jos_fb_moderation` ADD PRIMARY KEY ( `catid` , `userid` ) ; ALTER TABLE `jos_fb_ranks` ADD PRIMARY KEY ( `rank_id` ) ; ALTER TABLE `jos_fb_sessions` ADD PRIMARY KEY ( `userid` ) ; ALTER TABLE `jos_fb_smileys` ADD PRIMARY KEY ( `id` ) ; ALTER TABLE `jos_fb_subscriptions` ADD UNIQUE `thread` ( `thread` , `userid` ) ; ALTER TABLE `jos_fb_subscriptions` ADD INDEX `userid` ( `userid` ) ; ALTER TABLE `jos_fb_users` ADD PRIMARY KEY ( `userid` ) ; ALTER TABLE `jos_fb_users` ADD INDEX `group_id` ( `group_id` ) ; ALTER TABLE `jos_fb_users` ADD INDEX `posts` ( `posts` ) ; ALTER TABLE `jos_fb_users` ADD INDEX `uhits` ( `uhits` ) ; ALTER TABLE `jos_fb_version` ADD PRIMARY KEY ( `id` ) ; ALTER TABLE `jos_fb_whoisonline` ADD PRIMARY KEY ( `id` ) ; ALTER TABLE `jos_fb_whoisonline` ADD INDEX `userid` ( `userid` ) ;
row by row (cause some keys already existed) to add missing keys, if you get an error "dublicate entry", you should check if there are dublicats in the table and remove them
Last edit: 16 years 10 months ago by LOK.
16 years 10 months ago #37873 by PGLion
Today I upgraded to 1.5.8. and did the category recount thing. Now I also have duplicate messages and had to shut down my forum.
I don't have duplicate users, so that seems to be okay. What can I do to remove these double messages? Is it save to run LOK's code?
16 years 10 months ago - 16 years 10 months ago #37875 by PGLion
Hmm, I tried LOK's code but get this message:
Error
SQL query:
MySQL said: Documentation
#1068 - Multiple primary key defined
I must admit I dunno know much about SQL :(
Last edit: 16 years 10 months ago by PGLion.
16 years 10 months ago #38058 by PGLion
Everything is running smooth again but the problem still remains, I can not run "Recount Category Stats". It results in double entries of all messages in the database. How can I fix this?
