Kunena 7.0.8 Released
Question Ranks not displaying for Users
17 years 1 week ago #28058
by metaltome
Replied by metaltome on topic Re:Ranks not displaying for Users
The sidebar? As in the bar on the right which shows who posted the message? Yes.
17 years 1 week ago #28086
by eljefe
Replied by eljefe on topic Re:Ranks not displaying for Users
don't mean to intrude, but your discussion is similar to my question. How do you upload custom ranking images?
17 years 1 week ago - 17 years 1 week ago #28100
by skillless
Replied by skillless on topic Re:Ranks not displaying for Users
@eljefe
/components/com_kunena/template/default_ex/images/yourlanguage/ranks
put there your icons. if they got the same name as the old ones, they were loaded instantly, otherwise you have to configure them in kunena-backend.
Last edit: 17 years 1 week ago by skillless.
17 years 1 week ago #28128
by eljefe
Thank you. I am VERY new to all of this, so I'll look around and see if I can figure out where exactly that is. Thanks!
- cXc
17 years 1 week ago #28129
by cXc
Replied by cXc on topic Re:Ranks not displaying for Users
I'm not sure how it works in JomSocial but in CB we have the option of using the standard sidebar for K or get the info from CB, I'm thinking that its looking for the ranks in the JomSocial database table and not finding anything. With CB we can turn it on and off you might try different sidebar settings and see if you have ranks again with different settings.
Could help narrow down the problem ...
17 years 1 week ago #28141
by metaltome
Well that's the Integration part in JomSocial. I have Integration all set to JomSocial, so it should pull info from peoples JomSocial profiles. I looked at my jos_fb_ranks MySQL table and it has all the appropriate .gif images listed, so I'm really stuck on this one as to why they are not showing up.
Does Kunena have a mainentance script to check and upgrade/optimize all the SQL tables? I know it does this on install of Kunena, but I'm curious if I can run the SQL queries again somehow?
Time to create page: 0.238 seconds
