Question Ranks not displaying for Users
17 years 2 months ago - 17 years 2 months ago #28011 by metaltome
Over the past 2 days I've been battling a migration of Joomla 1.0.13 Fireboard 1.0.4 to Joomla 1.5.14 Kunena 1.5.5.
I have followed all the steps I've found in the forums and have successfully migrated the forums. Everything is working as intended except that Ranks are not displaying and members Profile avatars are linking to JomSocial sub-menu items (not users profile). I already posted another thread on the JomSocial profile issue, so this thread is mainly trying to figure out why Ranks are not displaying. I am attaching a screenshot:
P.S. Could this have something to do with my prior Fireboard forum being linked to Community Builder and I have Kunena set to JomSocial (So it's having some form of Rank conflict?). When I originally migrated the forums I only migrated jos_fb_messages and jos_fb_message_text and Ranks displayed correctly. It's when I migrated jos_fb_users to display members "posts" that Ranks vanished. I've also Sync'd Users from Kunena... no help. Thanks for any help you guys can give me!
Last edit: 17 years 2 months ago by metaltome.
17 years 2 months ago #28030 by xillibit
In the Kunena administration panel, in ranks management you have defined something ?
17 years 2 months ago - 17 years 2 months ago #28050 by metaltome
Yes everything is defined as default settings. I've looked at Ranks Management like 5 times just because I was running out of ideas. I followed FB 1.0.4 to Kunena Joomla 1.5 instructions:
Installed Kunena 1.0.11 on my Joomla 1.0 site. Then exported all my jos_fb tables and imported them to my Joomla 1.5 site and installed Kunena 1.5.5. Everything seems to work except Ranks and any URL that is supposed to go to a users JomSocial profile is directing them to a sub-menu alias underneath my JomSocial main menu item (See: www.kunena.com/forum/11-jomsocial/28009-...ects-to-submenu-item ). Other than that the migration looks to be successful. Just trying to figure out how to fix these 2 remaining issues.
  • cXc
  • cXc's Avatar
  • New Member
  • New Member
17 years 2 months ago - 17 years 2 months ago #28051 by cXc
Replied by cXc on topic Re:Ranks not displaying for Users
Did you use custom images for your ranks in FB?
When I upgraded I had to move my rank images from my FB template to my K template to get them to show up.
[edit] Nevermind reread thread ... [/edit]
[edit] Well can't hurt to ask anyway so put my post back :P it might help someone else figure out what your problem is anyway ;)
I had a couple more questions anyway, what browser are you using and does it do that in Firefox?
Have you tried using Firebug to see if the image is in the location it expects it to be in? [/edit]
Also you probably already have but if you haven't you might look back over your config and make sure when you reinstalled the sql it didn't revert to your FB settings ...
Last edit: 17 years 2 months ago by cXc.
17 years 2 months ago #28054 by metaltome
Yes I've inspected the element where the Rank image should display, thing is it doesn't display the text above the image like it should either. The element in Firebug where the Rank image should show up just shows this for every member:
/components/com_kunena/template/default_ex/images/english/ranks/
so it's not actually trying to pull up a specific .gif. I've made sure that the URL path actually exists and it does, and has all the appropriate images within the /ranks folder.
  • cXc
  • cXc's Avatar
  • New Member
  • New Member
17 years 2 months ago #28056 by cXc
Are you using the sidebar?
I'm just getting started with Kunena myself and upgraded a couple days ago, I'm not live yet with it cause I have a post preview bug so I'm really just trying to guess.
:unsure:
