Question Avatar upload doesn't work
17 years 4 months ago - 17 years 4 months ago #23625 by @quila
Hi WrongWay,
do you talking about this drop down list?
for which template the graphics folder is not there?
Regards
Last edit: 17 years 4 months ago by @quila.
17 years 4 months ago - 17 years 4 months ago #24179 by Lintzy
Please try this, this worked for me, the problem is sys_get_temp_dir () and php version 5.2.0, where this function is broken.
For Kunena 1.5.4
Edit kunena.file.class.php (/components/com_kunena/lib/)
and replace the old code with new code:
old:
function tmpdir() { static $tmpdir=false; if (!empty($tmpdir)) return $tmpdir; if (function_exists('sys_get_temp_dir')) { $tmpdir = sys_get_temp_dir(); } else { $file = tempnam(false,false); if ($file === false) return false; unlink($file); $tmpdir = realpath(dirname($file)); } return $tmpdir; }
new:
function tmpdir() { static $tmpdir = false; if (!empty($tmpdir)) return $tmpdir; //Try php >= 5.2.1 functionality if (function_exists('sys_get_temp_dir')) { $tmpdir = sys_get_temp_dir(); $file = tempnam($tmpdir, false); if ($file !== false) { unlink($file); return $tmpdir; } } //Try php setting $tmpdir = ini_get('upload_tmp_dir'); $file = tempnam($tmpdir, false); if ($file !== false) { unlink($file); return $tmpdir; } //Last resort, try system tmp dir $file = tempnam(false, false); if ($file !== false) { unlink($file); $tmpdir = realpath(dirname($file)); return $tmpdir; } return false; }
Or use the attached file for Kunena 1.5.4 kunena.file.class.php and override the existing file in components/com_kunena/lib/
File Attachment:
File Name: avartaruploadfix.zip
File Size:1.53 KB
Last edit: 17 years 4 months ago by Lintzy.
16 years 2 months ago #60856 by AdminEuroCompanyFormation
Hi.
Got same problem
JFile::copy: Cannot find or read file: ''
Installed version: Kunena 1.5.12 | 2010-06-19 | 1897 [ Calificar ]
16 years 2 months ago - 16 years 2 months ago #60859 by AdminEuroCompanyFormation
Oh sorry already find solution HERE
Last edit: 16 years 2 months ago by AdminEuroCompanyFormation.
