Question An upgrade problem not solved ...
17 years 2 months ago #27967 by saronno
Could it be possibile to have at least a hint? Where could it be the problem?
Which function manages the emoticons and can cause the problem?
:dry:
17 years 2 months ago #29424 by xillibit
Do you have tried with Kunena 1.5.5 and the template default_ex ?
17 years 1 month ago - 17 years 1 month ago #30773 by saronno
I upgraded to 1.5.6 ... there is no way ...
The problem is not solved. Of course there is a bug in the parser who translate the selected words in the appropiate emoticon links.
<img src="localhost/joomla/components/com_kunena/template/dorona_ex/images/english/emoticons/<img src="localhost/joomla/components/com_kunena/template/dorona_ex/images/english/emoticons/occhiolino.gif" alt="" style="vertical-align: middle;border:0px;" />.gif" alt="" style="vertical-align: middle;border:0px;" />
As you can see and as I previously described kunena put an entire img tag within the other instead of put there simple the right world odentifying the right gif.
Last edit: 17 years 1 month ago by saronno.
17 years 1 month ago #31266 by saronno
I got it!!
If you have the code equal to the name of your icon file it doesn't work.
Es. emoticons code:ehila
This is not an upgrade problem, it regards the forum code.
I don't know if it should be tagged as BUG or something else,
but I think it deserves attention.
17 years 1 month ago #31289 by xillibit
I will report this to the DEVs, but i don't know it's a bug or not.
17 years 1 month ago #31676 by Matias
Well, it's a feature of K1.0 and K1.5. :)
It will be gone in K1.6 which has better bbcode parser.
