Question An upgrade problem not solved ...
there could be a problem with the old messages.
In this post www.kunena.com/forum/105-solved--support/7678-invisible-post
somebody claims the problem was solved but it is not.
Trying a migration a couple a day ago, the same problem came up.
Some emoticons appeared, others not, and in the text of the message you can find this thing:
As you can see, it is as kunena inserts a complete image tag within another instead of simply adds the name of the appropriate gif for that emoticons.
In my production website, I'm still with fireboard because of that (and I'm worried about resulting security problems of that choice)
From the editor:
tutto ok grazie.
E' stata solo dimenticanza. Lunedi li chiudo. occhiolino
From the thread in the message board
tutto ok grazie.
E' stata solo dimenticanza. Lunedi li chiudo. .gif" alt="" style="vertical-align: middle;border:0px;" />
From the Kunena admin panel
From phpadmin (emoticons table)
I selected a template named dorona_ex with Image sets dorona_ex too.
occhiolino.gif is in public_html/components/com_kunena/template/dorona_ex/images/english/emoticons
As I said previously, this is an upgrade from fireboard 1.0.5 where everything was working fine.
Everything seems correct, so I think the problem could be in the code somewhere.
If I post a new message, with occhiolino emoticons ... same problem.
www.kunena.com/forum/139-solved-or-prior...-problem-not-solved-
My workaround to this problem is a bit "clunky" but it seems to do the job.
The smiley images that you want are stored in the folder ../components/com_kunena/template/dorona_ex/images/english/emoticons. If you copy all those files to the folder ../components/com_kunena/template/default/images/english/emoticons I think you will fix your problem.
I have to admit that this is more folklore than science and I've been doing this ever since the days of K 1.0.7b (maybe even earlier!). My recollection is that I needed to copy of all my emoticon images from the folder I'd chosen in the Kunena configuration settings (e.g. default_ex) to the default folder as well. I can't confirm that this is the case but it's something you might like to try.
Perhaps other people can shed more information on this mystery?
I don't understand why this thread was closed for the second time.
However, the problem is still there ... I tried what sozzled suggest, but without success. I still sadly with the old fireboard ...
I can't put kunena on my production server if it does a mess with my messages ... :blush:
