Important For Info
Joomla 1.0 dependent?... and, yes, the entire site is very Joomla dependent.
Do you know of a way to fix the escaped quote issue without upgrading?slave2six wrote:
I have no idea whether an upgrade to K 1.5.3 will address the "escaped quote" issue in your signature. If you look at my signature here, you will see that I use quotation marks. There is no backslash character.Question: Should we install Kunena 1.5.3 in place of Fireboard 1.0.4 in order to resolve this issue? Will this cause any kinds of configuration issues for us?
In that case I see no obvious reason that prevents you upgrading to K 1.5.3. YOu should, of course, check the release notes to ensure that your versions of PHP and MySQL meet the minimum requirements.Joomla 1.5.9
The number one reason to change from Fireboard to Kunena is a fairly simple one: support. Fireboard is old, there is no official support for it and it's only used by dedicated enthusiasts (or those who don't haven't the time, energy or effort to make the five-minute changeover). It's a bit like choosing a wind-up watch over a digital one; they both tell the time ... to varying degrees of accuracy. One of them you have to send to the watchmaker for repairs, the other you can replace for a couple of dollars down at the local supermarket. It boils down to decisions based on choice, preferences and long-term maintenance consequences.
Do I know of a another way to fix my broken wind-up watch? Do I care? I just get a new one. Problem solved.
LOL! Yes. You make valid points and since we are in pre-launch, now would be the best time to upgrade. Thanks so much for all your input.Do I know of a another way to fix my broken wind-up watch? Do I care? I just get a new one. Problem solved.
