- Thank you received: 565
Important For Info
This discussion can be safely moved to the "solved" category.
Can you please give me the file where this modification appear
Thanks a lot
can also confirm that the extra backslashes (to "escape" single- and double-quotes), when a user edits their posts, these no longer appear. Thank you.
For example, if I use the following quote in my signature:
"Famous Quote"
The system displays it like this:
slash "Famous Quoteslash "
Question: Should we install Kunena 1.5.3 in place of Fireboard 1.0.4 in order to resolve this issue? Will this cause any kinds of configuration issues for us?
Unless there are other reasons that prevent you upgrading to K 1.5.3 (such as your dependence of Joomla! 1.0.x, for example) why are you still using Fireboard ... and an old version of Fireboard into the bargain?Question: Should we install Kunena 1.5.3 in place of Fireboard 1.0.4 in order to resolve this issue? Will this cause any kinds of configuration issues for us?
I have no idea whether an upgrade to K 1.5.3 will address the "escaped quote" issue in your signature. If you look at my signature here, you will see that I use quotation marks. There is no backslash character.
And, yes, the entire site is very Joomla dependent.
