Kunena 7.0.8 Released
Question How to change the title in Kunena forum
17 years 1 month ago - 17 years 1 month ago #22683 by sozzled
I must confess to you that I was using K 1.0.10 as my basis for suggesting which areas of code needed to be changed. I wasn't sure whether K 1.5.3 is significantly different in this regard. It appears my assumptions were probably incorrect.
I'll have a look at K 1.5.3 to see what changes are indicated. I would suspect that, even if the line numbers are different, the structure of the PHP code that needs to be changed should be roughly similar. I won't be able to test the results until I have upgraded to K 1.5.3 myself.
The relevant area has to do with a call (or calls) to to the setTitle class/function.
Last edit: 17 years 1 month ago by sozzled.
16 years 3 months ago - 16 years 3 months ago #49302 by drnda
I've found the solution in a harder way :
fb_layout.php
fb_pathway.php
latestx.php
listcat.php
I've edited every single file of the above, and looking for the line where "board_title" is mentioned, then moved it to left, and what was left, I've moved it to right - simple change the order in code, but you have to be very careful, always download it first, save, then edit so,in case of some mistake - you will be able to restore it later.
So the key is to find "board_title" and move it.
example :
before
$document->setTitle(_KUNENA_ALL_DISCUSSIONS . ' - ' . stripslashes($fbConfig->board_title));
after editing
$document->setTitle($fbConfig->board_title . ' - ' . stripslashes(_KUNENA_ALL_DISCUSSIONS));
You must not move the phrase "stripslashes", only move what's in brackets.
I am sorry for my english, but I hope you've understood.
p.s. I am a simple user, If I did it, anyone can :)
Last edit: 16 years 3 months ago by drnda.
Time to create page: 0.233 seconds
