- Thank you received: 2
Kunena 7.0.8 Released
Question How to change the title in Kunena forum
I have a problem with my forum. I allready created a thread when I was using an older version of Kunena. Meanwhile I have switched to 1.5.3.
The thread with the problem is locked because the moderator Matias thought his answer had resolved the problem but it didn't.
This is the thread.
www.kunena.com/forum/93-solved--support/...itle-in-kunena-forum
The user sozzled understood my question. I don't mind it says : Categories on the forum but I do have a problem with in Internet Explorer or in Firefox in the title it says : Categories! I do not want that at all. I just want to have it in the title of the browser to say : My website forum's name. But first you see that 'Category'.
This is what I would like to see changed! But how???
Also I'm searching for another problem : changing the position of the avatar, posts, ... to the left side but the search function isn't very helpfull. If you could point me into the right direction, would be great. Thanks!
Here's what you would need to do (assuming that you're using the default_ex Kunena template):
1. For the categories: edit the file ../components/com_kunena/templates/default_ex/fb_layout.php at line 148
Cheers
sozz
PS Thank you for your eventual acknowledgement in relation to the older discussion. We don't always get thanked for the help we provide. I spent about an hour-and-a-half looking into this matter on your behalf. I hope that it was worth the effort.
Thank you for responding. I will give it a go. As for changing the left side, I have searched before but will look again.
That can be found here for Kunena 1.5.3: www.kunena.com/forum/114-hacks/20161-kun...-on-right-side#20565As for changing the left side, I have searched before but will look again
Thanks for your help. I'm currently trying it. I use indeed the default_ex template but the codes you told me to look for are a bit different than what I found in my default_ex template. I have no idea why that is.
I found the following code on row 135 :
and I changed it into
But for the Categories I seem to be stuck
In the fb_layout file I can only find this code for the categories:Can you perhaps help me again with this?
