Question Beginners Question Kunena Look
17 years 5 months ago #21402 by sozzled
Cannot view mad.divethephilippines.com . You're still adding other components, it seems. Please advise when site is stable/viewable.
17 years 5 months ago #21403 by sozzled
If you want my brutal, honest opinion, I think you're going about this the wrong way.
The problem stems from using a very narrow-width Joomla template. This kind of a template is probably not well-suited to handling a Kunena forum. This explains why it's "necessary" to attempt to strip the Joomla template from the Kunena forum pages. However, by opening the Kunena forum in a new browser window and removing the browser's navigation, that's making life miserable for your users. What if they want to go back a couple of pages? Where's the back button? It's not there, of course!
I think that there's a simpler solution if you use a flexible-width Joomla template. There are millions of them around. Or use a Joomla template that is wider than the one you're currently using. Why, after all, is it really necessary to fill up the user's browser window with so much blue? I understand, blue suits the "diving" theme ... but surely there are other designs that will serve your purpose and do it much better, aren't there? :unsure:
Before you look for a solution, always ask yourself first, "What's my purpose?" Sometimes aesthetics have to be compromised against functionality.
17 years 5 months ago #21404 by geurtd
Yes your right, i am going about this the wrong way, thx for all you help.
