Question [External - solved] CSS Conflicts Galore!
17 years 5 months ago - 17 years 5 months ago #20924
by JBHawaii
Mahalo,
JBHawaii
Replied by JBHawaii on topic Re:CSS Conflicts Galore!
actually the problem is the alignment of the tables...
as far as the template matching the theme, I'm not concerned about that because I will design one.
I just want to know if this below is normal... the left side seems unjustified as compared to the right side.
Mahalo,
JBHawaii
Last edit: 17 years 5 months ago by JBHawaii.
The topic has been locked.
17 years 5 months ago - 17 years 5 months ago #20926
Replied by sozzled on topic Re:CSS Conflicts Galore!
Ahh ... I see the problem now. I needed to use a magnifying glass!
Yes, the left-alignment of the elements is a little ragged. If the truth is known, they're probably ragged on every website where people use the default_ex template; however, because most sites (I suspect this is the case) use a white background, the "raggedness" wouldn't be apparent. I should also add that <div> and <table> container heights and widths are handled differently by Internet Explorer compared with other browsers ... but you probably knew that already.
The issue is probably addressed by looking at the margin-left or indent CSS attributes of the elements. That's just a guess. Good luck, mate.
Last edit: 17 years 5 months ago by sozzled.
17 years 5 months ago #20927
by Spock
Replied by Spock on topic Re:CSS Conflicts Galore!
Ahh ok, I see what you mean. This is a conflict is definitely with the Template plazza template and Kunena CSS.
Go to YOURSITEURL/templates/showcase_plazza/css/gridrender.php
change the following attribute
toborder-collapse: collapse;
See how that works?border-collapse: inherit;
17 years 5 months ago #20930
by JBHawaii
Mahalo,
JBHawaii
can't find that... I might have to dump this template. I think it's to much of a hassle.
Mahalo,
JBHawaii
17 years 5 months ago - 17 years 5 months ago #20932
by Spock
It is only a basic css conflict - so i wouldn't give-up (its a nice template really). This CSS attribute
(it works when i alter it in firebug)
check if there is possibly a gridrender.css file in the template directory and i think you'll find border-collapse somewhere in it.
should be in a template CSS file that controls the plugin above (gridrender.php)border-collapse
Screenshot with problem fixed:
Last edit: 17 years 5 months ago by Spock. Reason: Screenshot added
17 years 5 months ago - 17 years 5 months ago #20935
by JBHawaii
Mahalo,
JBHawaii
I have altered the kunena.forum.css now and resolved that alignment issue
I as much as possiblt try to stay away from changing the joomla template. because the result can be un-wanted when viewing other content instead of the forum.
I added
to several sections. this was easier then I thought. now I can start to customize it
Thanks so much fellas for pointing me in the right direction
I think it's safe to say this topic can be marked as Solved.
I added
Mahalo,
JBHawaii
