Question [External - solved] CSS Conflicts Galore!
CSS Experts here is a challenge I'm sure will give you a run for your money.
Website details:
www.jbhawaii808.com
Username: Kunena
password: Kunena
Any help to resolve this nightmare is welcome. I've spent several hours trying to figure this one out, with no kind of luck.
I bought the joomla template from template plazza and it's perfect for what I want to do, however it's not pretty right now.
Thanks in advance!
Mahalo,
JBHawaii
when I try to look in your forum
403 - You are not authorised to view this resource.
Regards
Mahalo,
JBHawaii
Seeking help to straighten out my forums... my joomla template is on hell of a CSS Nightmare. It completely conflicts with kunena's default_ex template.
JBHawaii,
I had a look just now (Using FF3) and it all looks fine exept the fact that it does not match backgrounds/fonts/graphics. How do you mean conflicts? Is it that it just doesn't match your Joomla! template or are there any alignment and display problems in a particular browsers? Please be as specific as possible and I should be able to help
Regards
I think the question is "how can I match Kunena to my Joomla template" not, "how can I match Joomla to the Kunena default_ex template"? At least, I hope that's the question. :laugh: The answer, obviously, is to systematically work through the Kunena CSS stylesheet.
There are many ways of realising this solution. One of the easiest ways is to use Firebug. (As a recent convert to Firefox I was very impressed with how easily Firebug identifies and allows you to change, on-the-fly, CSS.) Obviously, Firebug doesn't change your site's CSS stylesheet in situ but it does allow you the opportunity to experiment and shows you which files are involved. It should help transform your CSS nightmare into a bit more of a dream.
- Thank you received: 2545
