Question Need help with last little bits on template
16 years 3 months ago #50605 by Matias
I'm sorry cally, if you got the feeling that we are looking down our noses here. That was not our intention. Our team has been very busy lately on trying to finish Kunena 1.6 while trying to manage their own lives and work. Sleeping too short nights sometimes shows up, even if we are trying to avoid showing it.
Our team always welcomes constructive critic and we will try to improve our replies, even if Cerberus took it very personal that his favored moderator received some negative feedback.
I must agree others on Gainsboro; it hasn't been updated for a while and we have gradually made some changes that makes the old templates incompatible with the latest releases. I hope that the author is willing to upgrade his template for K1.5.12, as it seems to be pretty popular one.
In the mean time, I would install older release of Kunena if you want to use this template.
16 years 3 months ago #50607 by cally6008
Hi Matias :)
Hey no worries, I get the same way only mine is due to illness n sleep problems.
I did play around with Gainsboro some more last night and even attempted doing a "compare files" thing as there's currently 3 version of Gainsboro on the go (the normal one, the left one which has profile box on left and the european time one) and ideally I'd love it to be all 3 versions rolled into one. Only lasted bout 10 mins though :laugh: and gave it up as a bad job.
I've stuck with the default_ex template and Kunena 1.5.11 and am not going messing with anything especially after reading one of sozzled's posts where he/she put that there had been 13 releases of kunena over a 12 month period! Definitely sticking with simple and standard, why make more work for myself ? I never learn :laugh:
16 years 3 months ago #50625 by @quila
Hi cally,
sorry for delay to answer you on this topic.
Well, the template you are using (Gainsboro v2.0) IS UPDATED and run without problems in K 1.5.11 and upcoming k1.5.12 (now we are about just to release it). In few minutes when you see k1.5.12 out, upgrade kunena and download template again (only) from here and dont use template in the middle of discussion of Gainsboro template. I mean this #36095 .
That version is not supported by me and is modified by other user. I suspect you are trying to use that one and you have some problems.
If you still have problems after update let me know.
Best Regards
16 years 3 months ago - 16 years 3 months ago #50627 by @quila
Cerberus wrote:
ok were do i start with this one, hmm ok i will start with No gainsboro v2 is NOT fully compatable with kunena 1.5.11 there are flaws in it.
do a search here for gainsboro and you will see lots of ppl having issues with it
Gainsboro Template V2.0 IS fully compatible with K1.5.11 and K1.5.12
Please be careful and sure what you are write about this template. If you have some problems with that template or you can find some user which have problems let me know and I'll try to help you or others.
Thank you
Last edit: 16 years 3 months ago by @quila.
16 years 3 months ago #50628 by Matias
Great news, @quila!
I really like your template, so let's make sure that also get ported to K1.6 before it goes out. ;)
16 years 3 months ago #50633 by @quila
Sure,
that's work-in-progress for K1.6 ( and there will be more ;) )
