Question changing colours in tabs
16 years 6 months ago #47765 by chicaloca
hi
i posted about this a while back but I've only now began to look at the answer and trying to figure it out.
basically ive got this:
kds.dkeenan.co.uk/index.php?option=com_kunena&Itemid=37
and I'd like to change the tab colours to something more fitting with the colour scheme.
I've used firebug and i think I've found what I need to change. Its called tabmenuleft in the images folder and looks like the image I've attached. What I want to do is change the background colour of the tabs both when theyre rolled over when they are. Its tricky to tell in the css as every time the mouse is hovered over part of it then removed it changes. Would it be that image I need to change in addition to some css? Any pointers would be great :)
16 years 6 months ago #47794 by sozzled
Yes, well, CSS isn't going to help you, unfortunately :(
The tab colours are generated by images. What you need to do is to edit the background images (there are four of them) using image editing software (like Paintshop Pro) and change the "blue" part into something more fitting.
It's a bit of a fiddle.
I created a few images for one of our users that might help: see How do I change the background colours of my tabs? which I referred you to in a question you asked on the same subject a while ago. The answer to your question is the same. :)
16 years 6 months ago #47801 by woonydanny
i have my tabs just with css. i deleted the reference to the images in the css file and just specified colours instead. nothing fancy :)
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile :(
16 years 6 months ago #47812 by chicaloca
hi :)
thanks for both answers. sozzled i did look at that thread originally but have to admit it didnt make much sense at the time! I've used the zipped images you've done instead of trying to work out how to do it myself :) thanks
